lighting problem someone please help me!!!!!
Old Oct 29, 2008 | 10:34 AM
calboi's Avatar
Default lighting problem someone please help me!!!!!
ok so when i turn my lights on everything comes on fine, but my interior lights such as my climate control lights and my gauge cluster lights. i have checked every fuse and everything seems to be fine i have even tried put a new gauge in it and nothing happens. plz help.thanks
o and the car is a 94 integra rs
Old Oct 29, 2008 | 11:17 AM
champLSinteg's Avatar
Default Re: lighting problem someone please help me!!!!! (calboi)
You might have the dimmer all the way off? It the **** on the dash to the right of the steering wheel column.
Old Oct 29, 2008 | 11:47 AM
calboi's Avatar
I no which one it is and i have already tried that its fine also
Old Oct 29, 2008 | 12:24 PM
ProjectFlatline's Avatar
New User
Default Re: (calboi)
Are you sure you've checked everything? Under the hood/ under the dash? Made sure that some of the fuses don't share two things?
Old Oct 29, 2008 | 12:27 PM
SuzukaBlueAP2's Avatar
tell us exactly what does not illuminate. phrases like such as leave room for assumption.
do all of your external lights work? brake lights?
how about all headlamps, parking lights and turn signals?
does your dome light work?
Old Oct 29, 2008 | 12:40 PM
calboi's Avatar
everything works fine except the climate control lights and gauge cluster lights
Old Oct 29, 2008 | 03:29 PM
i would double-check all of those fuses under the dash again. Make sure they are all seated properly too. Maybe one just isn't pressed in the whole way?
If I get a moment I could go look under the dash of my 94 LS and get some better ideas.
Old Oct 29, 2008 | 03:56 PM
calboi's Avatar
thank u cause i went out there a min ago and pulled out and it looked fine the digrahm also said my tailights and licesne plate lights come off that fuse but thwey work fine also
Old Oct 29, 2008 | 03:59 PM
egsleepercivic's Avatar
I haven't had my teg but for a couple of months but this seems to be a common issue, from what I have read the dimmer switch seems to go bad, if you have a friend with a teg try swapping in a known working unit
gl
Old Oct 29, 2008 | 04:11 PM
calboi's Avatar
yea ima try and see what happens
Old Oct 30, 2008 | 05:56 AM
calboi's Avatar
anyone else have anymore input
Old Jul 2, 2009 | 06:41 PM
jdm.I.am's Avatar
bump, i have the same problem right now in my 95 integ also.
Old Jul 3, 2009 | 11:40 PM
jdm.I.am's Avatar
bump.
Old Jul 4, 2009 | 12:13 AM
teggyboy's Avatar
Does anything in your gauge cluster/climate control light up at all? If you are sure it isn't a fuse problem, it is very likely to be a wire/electrical problem. When did this start happening and did you do anything prior to it? When you swapped clusters did you swap the bulbs as well?
Old Jul 4, 2009 | 07:00 AM
honda_coupe's Avatar
not sure if this has been said or not, but check all your grounds
Old Jul 4, 2009 | 09:48 AM
jdm.I.am's Avatar
all of my gagues work (tach, speed, fuel, temp) and all the little lights like battery and check E lights its just the back light that lights up the cluster at night. and also the climate control little lights work that tell you what setting it is on (green/orange) but the back light for night time is out.
Old Jul 4, 2009 | 05:18 PM
J1NKS's Avatar
do you have a volt meter? check for voltage if you changed the gauges its not the bulbs unless you fry them as soon as you hook it up. check the voltage and trace it back to the fuse box. also try to bypass your dimmer swich with a jumper temporaraly check the voltage on the line side and the load side of your dimmer.
Old Jul 4, 2009 | 05:22 PM
kchungb17a's Avatar
Have you pulled your dimmer switch out to see if it's plugged in? Anybody have your dash apart lately?
Old Jul 4, 2009 | 08:52 PM
jdm.I.am's Avatar
i pulled off the cluster trim to get to the dimmer switch and found out the dumb *** that i got the car from cut one of the wires for the dimmer switch to run it as a power wire for the radio.. how stupid.
problem fixed.
shoebox
Sep 28, 2012 04:39 AM
slob20ef
Mar 30, 2009 05:43 PM
Chef Andre
Feb 23, 2007 06:00 PM
philkehn
Nov 5, 2006 08:39 PM
cdx280
Jan 29, 2006 03:46 PM
