door hinge noise?
So lately when I open (only open, not close) the driver's side door, it makes this loud squeaking sound, sounds like I'm bending metal with a compactor lol... Only seems to happen in really cold weather.
Any ideas to why this is happening and what I can do about it? I'm going to try and WD40 the hinges but I'm not sure if that'll do much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milanoteg »</TD></TR><TR><TD CLASS="quote">Any ideas to why this is happening and what I can do about it? I'm going to try and WD40 the hinges but I'm not sure if that'll do much.</TD></TR></TABLE>
This should fix it
This should fix it
that actually might be the case. I bought the car without a liner on that side. I'm taking a look at it tomorrow morning i'll let you guys know if it's not an issue of being cleaned/greased up.
If the liner has been off for awhile I suggest taking the guard right off and cleaning all the dirt out, Then put it back on and use some sealant in the gap by the hinge under the guard. Should stop the problem coming back.
K turns out part of the hinge was broken, making the door hang a little bit lower, scraping against the other part of the hinge/doorjam.
I went to a junkyard today and found another hinge, put it on and everythings fine now.
Thanks everyone who offered suggestions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow »</TD></TR><TR><TD CLASS="quote">If you know the answer already then why ask? Like I said before, it isn't the hardest of fixes.</TD></TR></TABLE>
Actually I didn't know the answer already, I was asking to see if anyone had any similar problems. Seriously you shuoldnt post if all you're going to do is be a dick. I know this is honda-tech, but chill out a little.
ksettles619
Apr 27, 2012 11:49 PM
4twenty_CRX
Jun 4, 2007 10:48 AM
<< Do that less
