no pressure on clutch pedal...
Old Oct 29, 2008 | 01:12 AM
preludeh22a1's Avatar
Default no pressure on clutch pedal...
hey people I converted mine to auto to manual and i used a used xtd 6 puck clutch. when I finish the swap the clutch was high so I had it adjusted it to be low but its still high so I just dealt with it (6months). today I felt the clutch was stiffed and it grabs fast so I was kinda happy, I was leaving at work then the pedal has only freeplay when pressed its already to the floor, it would go into gear when its off but when it on it wont go to any gear...
Heres what I tried so far:
I tried to adjust the pedal height but its still low. Ive looked at the manual and its suppose to be 7.48" and mine is in 5.5" and im all the way out already on the rod.
I need to get it fix... what do u guys I think...
thanx for in advance.
Old Oct 29, 2008 | 05:58 AM
mgags7's Avatar
sounds like you have a leak somewhere in the clutch system. fix the leak, then bleed the system.
the helms manual has a procedure for adjusting the clutch rod for the proper amount of play. You should have about 1 inch of play at the top of the pedal, and the clutch engagement/disengagement point should be nowhere near the floor.
Old Oct 29, 2008 | 06:15 AM
f22builder's Avatar
Default Re: (mgags7)
. Did you say the pedal is on the floor? I would adjust the pedal to normal spec height and work from there.
May need a new clutch slave cyclinder? $34.99 autozone (they rust but work)
Check for leaks. What kind of brake fluid did you use? I believe it is brake fluid if not correct me.
Old Oct 29, 2008 | 06:51 AM
turboprelude97's Avatar
check the master cylinder all your lines and the slave for a leak it might just b that ur low on brake fluid so if its that it will b an easy fix
Old Oct 29, 2008 | 07:52 AM
Kronn 98SH's Avatar
Default Re: (turboprelude97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboprelude97 &raquo;</TD></TR><TR><TD CLASS="quote">check the master cylinder all your lines and the slave for a leak it might just b that ur low on brake fluid so if its that it will b an easy fix
Always check fluid levels first.
Old Oct 29, 2008 | 07:54 AM
mgags7's Avatar
filling the fluid reservoir up is a temporary fix
brake fluid doesn't just disappear, if your fluid is low, you have a leak. find it.
kalamoore
Nov 20, 2017 08:38 PM
morocco
Nov 13, 2007 03:27 PM
H22Honda98
Sep 21, 2007 07:36 AM
redman223
Jul 13, 2007 07:19 PM
ragejed
Jul 20, 2002 03:45 AM
