No FITV No Problem?
Old Oct 28, 2008 | 10:21 PM
eg8guy's Avatar
Default Help With FITV Question
i have an obd2 ls throttle body and ive noticed it does not have a fitv...my motors obd1...is this going to make a diffrence if i dont run the fitv?
Modified by eg8guy at 11:53 PM 10/28/2008
Old Oct 29, 2008 | 06:40 AM
eg8guy's Avatar
Default Re: Help With FITV Question (eg8guy)
Bump! No One?
Old Oct 29, 2008 | 01:28 PM
eg8guy's Avatar
somebody?
Old Oct 29, 2008 | 06:59 PM
2slowGs-R's Avatar
it should be fine as long as your using the obd2 gasket for it. Some people run with the FITV valve pluged without using it. The only reason why people run with it is to help warm up the TB when cold starting it up, many people believe that without the FITV it frees up some HP because there is no hot TB warming up the air before it enters the chamber allowing colder flow into the cylinders. You should be fine!
Old Oct 30, 2008 | 08:18 AM
eg8guy's Avatar
Default Re: (2slowGs-R)
Great! Much Appreciated.
crispchris
Jun 1, 2011 01:44 PM
almostjdmeg
Jan 28, 2009 09:16 AM
eg8guy
Dec 8, 2008 02:00 PM
oxSLEEPERxo
Sep 5, 2006 10:39 PM
oxSLEEPERxo
Sep 5, 2006 06:32 PM
