Engine Trouble Code - Am I reading this right?
Old Oct 28, 2008 | 07:35 PM
Dman03GT's Avatar
Default Engine Trouble Code - Am I reading this right?
So I got the car running but now I have a check engine light, I've looked at several threads about how to read the light but its still a bit hazy. This is an '88 D15 OBD1 computer by the way.
Anyways... it blinks 10 times steadily, then a pause, and then 10 blinks again.. keeps doing that over and over. So I assume that's supposed to be code 10?
Code 10 says: Intake Air Temperature?
Old Oct 28, 2008 | 08:10 PM
D16SiHatch's Avatar
Default Re: Engine Trouble Code - Am I reading this right? (Dman03GT)
well if its blinking then its not obd1, its obd0. and yes 10 blinks is for the IAT sensor.
Old Oct 29, 2008 | 03:53 PM
Dman03GT's Avatar
whoops, sorry that's what I meant OBD0 - and thanks for the clarification... now as far as the IAT sensor .. does it just need to be replaced usually? Or is there something else that causes the code?
Old Oct 30, 2008 | 10:01 AM
jlicrx's Avatar
Default Re: (Dman03GT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dman03GT &raquo;</TD></TR><TR><TD CLASS="quote">whoops, sorry that's what I meant OBD0 - and thanks for the clarification... now as far as the IAT sensor .. does it just need to be replaced usually? Or is there something else that causes the code?</TD></TR></TABLE>if you just did a swap or had connectors unplugged, make sure you have the correct connector plugged into the IAT sensor - it is a 2-wire connector with red with yellow stripe and green with white stripe wires
Old Oct 31, 2008 | 07:39 PM
Dman03GT's Avatar
Default Re: (jlicrx)
Thanks for the suggestion, I will check on that. I did indeed recently swap a blown D15 for a fresh one.
Wilka
19
Mar 29, 2013 03:05 PM
bababab18
Sep 30, 2010 01:30 PM
sing
May 17, 2007 02:56 PM
Superhatch
Oct 16, 2002 07:11 PM
