Crx Si Sunroof Problem
Old Oct 28, 2008 | 05:58 PM
d00d00dumb87's Avatar
Default Crx Si Sunroof Problem
Ok i have this problem with my sunroof on my 91 crx si..
It opens fine but it wont close when i push the switch...
so for the past month i've been closing it manually but i want to get it to close on its own.. anyone got any ideas what it might be ? i went to the shop and they charging me 400 dollars to get that sunroof fix. I dont think its the motor right ? since it opens it should close back ... help me out plz. thanks
Old Oct 28, 2008 | 06:04 PM
sleepingciv's Avatar
Default Re: Crx Si Sunroof Problem (d00d00dumb87)
it might be the cable binding up trying to reel it back in
Old Oct 28, 2008 | 07:13 PM
redsi89's Avatar
Default Re: Crx Si Sunroof Problem (sleepingciv)
i'm having similar problems with mine. usualy when it opens it doesnt want to close and sometimes it wont even open. also when it doesnt open the wipers dont work either and thought they might share the same relay and that was going, just havent had a chance to dig any deeper yet. let me know if you have any luck
Old Oct 28, 2008 | 10:05 PM
djrockytharp's Avatar
those motors are old as hell, most likely culprit
Old Oct 29, 2008 | 02:46 AM
rbwdriven's Avatar
Default sunroof
or faulty switch.
there is a thread on I think crx resources about taking your sun roof switch apart. getting rid of the contact build up on the rocker switch.
I did mine a couple of years ago and it works great.
http://www.crxsi.com/repair/sunroof-switch/
Modified by rbwdriven at 3:55 AM 10/29/2008
Old Oct 29, 2008 | 04:40 AM
ChevelleSSLS6's Avatar
...at least you have a sunroof.
Old Oct 29, 2008 | 08:18 AM
Jet805's Avatar
Default Re: sunroof (rbwdriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbwdriven &raquo;</TD></TR><TR><TD CLASS="quote">or faulty switch.
Modified by rbwdriven at 3:55 AM 10/29/2008</TD></TR></TABLE>
hes spot on thats what was wrong with mine. I'd have to push the button 2-10 times to get it to open / close sometimes.
Old Oct 29, 2008 | 09:27 AM
thisiskev's Avatar
Default Re: sunroof (Jet805)
i had one with a bad switch. it did the same thing. it would open but not close. i got a differant switch and it worked like a champ.
or you could just get rid of the roof and go jdm glass top and not have sunroof problems. that'd be bad ***.
Old Oct 29, 2008 | 03:46 PM
crxdriver88's Avatar
Yea its just the switch. I just replaced it with a nicer newer oem one. was like 15 or 20 bucks from the dealer.
Old Oct 29, 2008 | 06:30 PM
Default Re: To everyone
Hey wsup everyone.
I read all the advice you guys gave me and that helped me out alot. Thanks.
btw, where can I find a jdm glass top ? That sounds even better. Does it open-close auto or is it just a pop up ?
Old Oct 29, 2008 | 07:05 PM
redsi89's Avatar
Default Re: To everyone (d00d00dumb87)
it doesnt open at all instead of the sunroof the sir's roof was almost entirely glass. if i was gonna go for the glass roof i would just buy a real sir and not mess around cutting and welding.
Dr.Fixit
Sep 20, 2013 04:42 PM
dev203d
Nov 3, 2010 07:39 PM
OCdude31990
Classic Hondas
Jul 21, 2010 05:48 PM
Canadian_EF
Jun 23, 2009 07:18 PM
b16a3delsol
Jul 5, 2007 08:45 PM
