starting problems in the mourning!!!!1
Old Oct 28, 2008 | 03:03 PM
thermostate82's Avatar
Default starting problems in the mourning!!!!1
Ok soI just bought the car and in the mourning it is really hard to start. I have a check engine light that is coming up telling me that it is the coolent temp sensor. Also I dont think that the fuel filter has ever been changed. would those cause me to have to push the pedal to the floor and pump it to get it to start in the mourning
Old Oct 28, 2008 | 03:41 PM
ludemniac's Avatar
Default Re: starting problems in the mourning!!!!1 (thermostate82)
first of all check that coolant temp sens related code
Old Oct 28, 2008 | 06:20 PM
AndyD's Avatar
Mourning? It's spelled morning!!!!!!!!
Pushing the gas pedal to the floor turns off the fuel injectors. Sounds like it flooding when you try to start it. My 240SX used to do that at certain temperatures. It was really weird.
Also, how old is your distributor cap and rotor?
Old Oct 28, 2008 | 10:30 PM
gstrudler's Avatar
Default Re: starting problems in the mourning!!!!1 (AndyD)
Clogged fuel filter could be a culprit; coolant temp sensor shouldn't really cause starting problems. To check on your sensor problem, make sure your coolant is topped off and if it hasn't been changed in a while flush it out and refill. Make sure you reset your ECU after you do this (just pull the 7.5amp fuse in the engine fuse box). Worse case you have to buy a new temp sensor, but I kind of doubt that's the problem.
aznjay510
Aug 29, 2009 12:18 PM
puertoricanboy90
Jan 28, 2009 10:03 AM
GSRdriver1104
Jan 22, 2008 09:58 AM
KingDanOne
13
Dec 6, 2006 02:56 PM
TIRENECK
Jul 23, 2003 08:00 PM
