what is the best motor swap for a DA?
Old Oct 28, 2008 | 01:02 PM
rollinonblades's Avatar
Default what is the best motor swap for a DA?
i wanted to see what everyone thought was the best motor swap in a DA, im about to do a swap but cant really decide what motor to swap in?? im wantin to go with N/A for a while and maybe a supercharge or turbo later... what is the best swap for a DA in your opinion???
Old Oct 28, 2008 | 02:34 PM
BoSox46GSr's Avatar
Default Re: what is the best motor swap for a DA? (rollinonblades)
That all depnds... what are your power goals, and what are you using the car for.
Old Oct 28, 2008 | 03:33 PM
Default Re: what is the best motor swap for a DA? (BoSox46GSr)
i use the car for corners, like low mph corners, so i dont really want top end power, i want the power in the low mph range. and also i like quick launches from 2nd to 4th gear.. never like to get into fifth speeds... just like being able to smoke being going down the street...
Old Oct 28, 2008 | 03:47 PM
HONDRETTI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollinonblades &raquo;</TD></TR><TR><TD CLASS="quote">i use the car for corners, like low mph corners, so i dont really want top end power, i want the power in the low mph range. and also i like quick launches from 2nd to 4th gear.. never like to get into fifth speeds... just like being able to smoke being going down the street...</TD></TR></TABLE>
you dont want top end power? honda vtec motors thrive in higher rpm's. you wont get much low end until you install f/i
Old Oct 28, 2008 | 03:53 PM
Rajin's Avatar
Buy A nissan.
Low End power heh
Old Oct 28, 2008 | 04:04 PM
gonmaro's Avatar
stick with an LS if you want to boost it. Supercharge it to keep the power lower and get rid of the lag. just rebuild an LS for with a few upgrades (pistons, exhaust APR bolts) and you'll have a pretty decent DA for a very low cost compared to the other swaps
Old Oct 28, 2008 | 06:17 PM
Default Re: what is the best motor swap for a DA? (gonmaro)
well what i meant by low end power is not low rpm's i want low speed power... like 2-3rd gear power... i mean i'm always in the high rpm range so i need something that can handle being at high rpms for long time spans.....
Old Oct 28, 2008 | 07:14 PM
stocker2shocker91's Avatar
I requested a short story for a title.
well all honda engines can stay in the high rpms for a while if taken car of properly.. The b18A your car came with is one of the more (torquey) engines of its class. If your using it for autocross or something like that just do intake header and exhaust.
you should be fine
Old Oct 28, 2008 | 07:55 PM
Default Re: what is the best motor swap for a DA? (stocker2shocker91)
yeah but im wantin an engine with lower miles and is a little more powerful... and one that is better to build.... so i was thinkin about the b18c1... but if im'a spend the money i dont see why not do the b18c5..... is it really worth the money for the c5????
Old Oct 28, 2008 | 09:57 PM
SOHC_4dr's Avatar
you dont know what you really want. you dont want high end power but yet your leaning tward the type r motor? be more specific with what you want
Old Oct 28, 2008 | 10:45 PM
majinsoftware's Avatar
b16b with b18c rods and crank make quite a nice engine.
Old Oct 29, 2008 | 12:35 AM
Default Re: (majinsoftware)
i was wantin the Type R because is a damn type R and its the sh*t, like i was saying, i like to be able to pull on anyone i come encounter with and be able to have good power going through the tight corners, i hit anywhere from 10mph corners (well 10mph suggested) to 40mph corners (again 40mph suggested not acutal speed) thats where im wanting my power. ultimatley i want my power from 20mph to around 75mph.... right now im runnin a b18a1 and a b16 tranny, im likin the short gears but still want more power to push those gears
Old Oct 29, 2008 | 01:02 AM
racebum's Avatar
Default Re: (rollinonblades)
i have what you could call a type r + motor and it's fun, faster than a stock GSR but it won't make your head spin. i would go with what you have low cost access to. either do the 18c1 and use it as it sits with a p72 ecu or if you do something custom get as many cubic inches as you can. a b20 bottom end with decent parts and a p72 or pr3 head will be your low cost way to more cubes. i would probably try and find a 18c1 with good compression with an ecu. $1500 gets you one around here. if it were me i would probably buy a JDM from hmotorsonline.com. GSR long blocks are $1699 and come out of low mile cars. if you don't build a new motor most of the JDM stuff is lower mileage than what people have driven the **** out of over here.
Old Oct 29, 2008 | 01:30 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: what is the best motor swap for a DA? (Rajin)
anything but a sohc....... unless that sohc was turbo'ed. Or have bisi shipp you one of his sohc monsters, lol. It all depends on what you want. Power, budget becomes a factor. And just because its a itr motor does not make it a street terror. My lsvt-t will walk all over a stock itr. So would a well built gsr or lsvt.
I would rebuild your bottom end and slap on a vtec head. Atleast you know your bottom end is built and has 0 miles. Get some nice cams, valve train if you decide to go wild. And make sure you get the dam thing tuned. That is the key
Old Oct 29, 2008 | 01:39 AM
Default Re: what is the best motor swap for a DA? (wrx-killer-Sti-eater)
yeah lsvt sounds good and everything, but i heard their hard to maintain. i heard something about gaskets and **** need to be replaces alot or something, whats the best head to put on a b18a1 block??? C1 or B16??
Old Oct 29, 2008 | 05:00 AM
90SiReX's Avatar
B20vtec(1vote)
Old Oct 29, 2008 | 12:35 PM
Default Re: (90SiReX)
so put a b20 head on it???? whats the key differences between b16 b18C1's and b20 heads on ls blocks??? what is the performance difference's???
Old Oct 29, 2008 | 01:59 PM
drew1's Avatar
live it stock ls and turbo it
Old Oct 29, 2008 | 02:01 PM
drew1's Avatar
i would stick with the ls block and go with b16 or gsr head
Old Oct 29, 2008 | 02:02 PM
drew1's Avatar
Default Re: what is the best motor swap for a DA? (HONDRETTI)
yea because i got a da my self and bout to be turboing
Old Oct 29, 2008 | 02:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollinonblades &raquo;</TD></TR><TR><TD CLASS="quote">yeah lsvt sounds good and everything, but i heard their hard to maintain. i heard something about gaskets and **** need to be replaces alot or something, whats the best head to put on a b18a1 block??? C1 or B16?? </TD></TR></TABLE>
if there built right there just like any other motor as long as you take care of them..to many people think that cause they put on a head that can go to 9000rpms the whole engine can..not the case unless you build the block.
But on a side note my buddy has a lsv that he drives daily and put probably 50,000 miles on it(since hes had it) and its still running great
Old Oct 29, 2008 | 02:05 PM
drew1's Avatar
i would go with the b16 they both got the same power
Old Oct 29, 2008 | 02:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollinonblades &raquo;</TD></TR><TR><TD CLASS="quote">so put a b20 head on it???? whats the key differences between b16 b18C1's and b20 heads on ls blocks??? what is the performance difference's???</TD></TR></TABLE>
lol he means a b20 bottom end with a b18c or b16 head.
Old Oct 29, 2008 | 02:48 PM
sintype's Avatar
get a K.
Old Oct 29, 2008 | 10:04 PM
Default Re: (sintype)
lol yeah i'll just toss a b16 head on there... so should i look for a b16a or b?? head and how should i build up the bottom?
