Need Help! 97 Civic, Searched, tried and no fix yet! PLZ Help!
Car: 1997 Civic Ex 5spd stock motor, ecu, and engine harness
Problem: Car cranks, check engine light comes on but dosent flash, fuel pump dosent kick on, no spark
What i have done: Checked all fuses, sanded & checked all grounds, replaced main relay, tried diffrent ecu, checked all wires from wire tuck soldered w/ shrinkwrap, pulled all the blower motor out from under the dash and looked at the majority of the wires, checked and it should be getting power to the main relay and ecu from all the constant powers and the grounds were good.
I honestly am out of ideas, the next option is cutting the wires at the relay and rewiring it so i know its not in the harnesses somewhere. I thought it might be in the ignition somewhere but i took it apart what i could and everything looked good. Any help would be greatly appreciated!
wtf r u doing lol....who says it has anythign to do with wiring? maybe you have a faulty component lol? scan your ecu for codes....and post what u come up with, if nothing, then you will have to resort to regualr diagnostic steps...check for spark compression fuel ect. if u need help lemme kno ;-)
07civicSI
11
May 11, 2007 08:35 AM
hondakevin21
Aug 2, 2006 03:22 PM
