clutch not grabbing
i was on my way to school this morning and right wen i go down the ramp onto the freeway.. i hear a knock.. like something is hitting in the engine.. so i pull to the side.. and try to put it back in gear and the clutch wont grab?
HELP ME
HELP ME
The clutch won't disengage? The shifter won't go into gear? Or the shifter will go into gear even without the clutch pedal depressed?
Knowing the symptoms can help us figure out if the clutch is not engaging, or is not disengaging.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DA9 »</TD></TR><TR><TD CLASS="quote">i can put it in gear w/o having to push down the pedal..
im newb so i dont really know..</TD></TR></TABLE>
My brother's car did the same thing - when the old clutch was completely worn down to nothing.
You've got a major issue if that's a new clutch. Did you get it all aligned properly w/ the clutch alignment tool and tighten the pressure plate down to the flywheel properly?
What has happened is that the clutch is not turning the transmission shafts like it should, so it's like you're moving the shifter with the clutch disengaged, even though you're not touching the pedal.
Whatever it is, you're going to have to drop the tranny again and check it out.
i didnt install it.. so basically.. im gonna go to the mechanic who did it and ask em to check it over again..make sure he tightened everything properly..he did use the align tool tho..
thanks.. ill keep update..
have you replaced the passenger axle recently?
same thing happened to me.
my problem was that axle i was using was just an inch short, so when i took a left turn, the axle popped off from the tranny and didnt want to grab anymore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DA9 »</TD></TR><TR><TD CLASS="quote">yes.. the mech. put in a new axle on the passenger side
yeah dude, that's going to be your problem.
what year and engine are you running?
and what axles did you purchase for the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DA9 »</TD></TR><TR><TD CLASS="quote">93 integra.. running stock LS b18a1..
its a axle from autozone..not remanufactured.. bought it NEW</TD></TR></TABLE>
yeah, same thing happened to me.
idk if this is true, but somebody told me that i needed to get a 99-00 civic si passenger axle.
somebody chime in and tell me if i'm right.
i juss checked it.. its the passenger side axle..iono if its loose or wat.. i jacked up the front.. put it in gear.. went out and spun the passenger side wheel and i hear the axle rattling? is the axle too small or just loose?
I requested a short story for a title.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DA9 »</TD></TR><TR><TD CLASS="quote">thanks guys..i really felt like throwing my car on craigslist and selling it</TD></TR></TABLE>
we have all been there a time or two
"the car that has given you the most trouble is also the one that has given you the most knowledge"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adankid »</TD></TR><TR><TD CLASS="quote">
1990-2001 Integra axles (except for the RS and Type-R)
1999-2000 Civic axles
1993-1997 Del Sol
1993-1997 Del Sol
