Shortblock Rebuild Questions
Old Oct 28, 2008 | 07:07 AM
D16SohcVtec's Avatar
Default Shortblock Rebuild Questions
My motor is burning oil and I'm thinking about tearing it down, boring it a size over, and throwing in new rings.
If I measure the bearings with plastigage and they are all still within spec does that mean I can just leave the bearings as is? Or should I just go ahead and throw new bearings in?
This is a d16y8, and it's my DD. I just want it to be as budget friendly as possible. Thanks
Old Oct 28, 2008 | 07:13 AM
ekb16's Avatar
i would rec. gettin new bearings and not using the old ones
Old Oct 28, 2008 | 07:16 AM
whereiscarmensandiego's Avatar
dont half *** a motor build bearings are 30$ on ebay if u are cheap. u need to replace bearings ,piston rings, and all seals as well as oil and water pump if u dont want to be stranded
if u are gonna do it do it once and do it right other wise u will get some more miles out of it and be doing it all over agian
Old Oct 28, 2008 | 08:14 AM
gsrhatch2356's Avatar
Default Re: Shortblock Rebuild Questions (D16SohcVtec)
cant be that budget if you are boring it out, that means you are already in it for some new pistons so you maybe want to sit down and price everything out so you know about how much you are looking at. there is no such thing as a budget rebuild that is done right but in comparision to getting another motor it is alot better.
revlimitcrx
Mar 3, 2007 05:00 PM
Revi
Sep 26, 2006 06:16 AM
hOndafienD 04
Jan 13, 2005 05:28 PM
PAB18Si
Apr 23, 2004 07:50 AM
Smoothy
Jul 31, 2002 12:07 PM
