help sohc vtec head
Old Oct 28, 2008 | 06:52 AM
ej6hatchie's Avatar
Default help sohc vtec head
im hella confused, i want to drop a z6 head on my y7, what other parts do i need? i have the z6 intake manifold, z6 head, vtec solinoid, z6 valve cover. can somone list the rest of the stuff i need? im getting the p28 ecu soon. thanks
Old Oct 28, 2008 | 06:59 AM
ej6hatchie's Avatar
Default Re: help sohc vtec head (ej6hatchie)
oh do i need to polish and port my z6 head/intake manifold? for best results?
Old Oct 28, 2008 | 02:39 PM
ej6hatchie's Avatar
ttttttt
Old Oct 29, 2008 | 07:23 AM
ej6hatchie's Avatar
egegw bump
Old Oct 29, 2008 | 07:37 AM
slo_hatch's Avatar
its in the faqs...only difference is your using a z6 head and they are using a y8 head....it should be about the same. of course there are obd differences...so idk how to help you on that part.
https://honda-tech.com/zerothread?id=735196
Old Oct 29, 2008 | 08:26 AM
ej6hatchie's Avatar
Default Re: help sohc vtec head (slo_hatch)
u think i can use any sohc vtec ECU? like from the older models. cause i was thinking of going to the junkyard and taking one off a si eg or somthing
Old Oct 29, 2008 | 09:38 AM
CivicSpoon's Avatar
You're going to need 9 head studs (or bolts) for the Y7 and 1 for the Z6, for the head to fit right. The 1 Z6 stud/bolt goes near the vtec solenoid.
If you have to pass emissions, you'll need an ECU that is close to the year of your car. If you're car is anywhere from '96-'98 (OBD2A), you'll need a '96-'98 ECU. If it's a '99-'00 (OBD2B), you'll need a '99-'00 ECU. If you don't need to worry about emissions, then you can use a '92-'95 ECU. But you'll need to buy an OBD2A or OBD2B (whichever OBD2 your car is) to OBD1 conversion harness, for the '92-'95 ECU to plug in.
Honda Daze
Feb 20, 2019 04:46 PM
vital123
17
Dec 22, 2009 06:04 AM
teaks92hb
Oct 16, 2009 12:37 PM
feriob12
Nov 22, 2003 10:20 PM
