where is the main relay (pgm-fi) on a 1990 accord no luck with search option on site
Please help I am trying to help a friend with a no start issue on a 1990 accord and cant find the main relay (I know from this site its under the dash but where abouts)but I found this site and boy its heped me determine I need to check the main relay great site thanks for your help in advance
Brett
Modified by closs2sx at 7:18 AM 10/28/2008
Brett
Lay on your back on the drivers floor board, remove the cruise control unit [silver box about 8"X4"] above that on the driver side of the steering column will be the main relay.
You will only see the base of it and the plug with the big fat wires going into it.
Grey box/Brown base. says "Mitsuba RZ-00XX" on the side of it.
You can cheat at this point and instead of unbolting the entire relay housing, use a small screwdriver to pop the guts out of the housing. [Top Tech Tip of the Day]
Usually the solder joints going to the relay coils [small connections] are the ones that are cracked and need to be resoldered.
deadhead23
Jan 15, 2021 10:43 AM
ddg2sailor
Aug 9, 2007 11:38 AM
