LS ecu hooked up to a D16
ok so heres the deal...
i have a 91 civic si with a d16y7 out of a 2000 civic in it but the intake is off the stock 91 si motor...
ok so here is my question i have a OBD0 b18 ecu hooked up to my d16. could that make my car slower??? cuz it boggs ever so slightly when i first hit the gas in nutural or with the clutch in...
there is no check engine lights and it runs just fine the motor has about 65,000 miles on it,,, could this be bad for the engine, just making it run too ritch or what???
thanks for the help guys
Holy crap this is an old school trick like ... 03 status
OP, do you have another ecu to test? Have you looked at your timing of cam and motor, inspected your plugs?
Check the easy stuff, I remember this trick from way back.
Agreed, its an OLD trick. I rembmer researching it over 4 years ago. Was going to run a cammed d16a6 off a pr4. It never came to be tho, the motor couldn't hold onto it's rods.
ya i just changed my plugs and it ran better it just still boggs sooo idk what to do... and yes it is timed proporly... im just wondering if the right ecu would kill that bogg but take away the high rpm power i get out of that motor... are you guys saying by oldschool trick that it should make my car faster???
if you are on the stock d16y7 cam than it isn't even as aggresive as a stock a6 cam. you should look into getting a pm6 for the time being. I don't think that that y7 can take advantage of the pr4 in its stock form.
dropd4door
Aug 11, 2003 10:03 PM
CLICC916
May 23, 2001 04:25 PM
