Buying new distributor...
Old Oct 27, 2008 | 10:58 PM
RSX2SIcivic's Avatar
Default Buying new distributor...
Just wanted to know, what does a distributor bring. Because my car has no spark right now an my cousing told me it could be my coil, or my distributor itself. If i buy the actual distributor, does that bring the coil as well? What is included?
Old Oct 27, 2008 | 11:08 PM
Jimmy's Avatar
Global Moderator
Default Re: Buying new distributor... (RSX2SIcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSX2SIcivic &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted to know, what does a distributor bring. Because my car has no spark right now an my cousing told me it could be my coil, or my distributor itself. If i buy the actual distributor, does that bring the coil as well? What is included?</TD></TR></TABLE>
No spark.. either bad ignition coil or bad ICM (ignition control module) aka ignitor.
If you plan on picking up a distributor at a parts store (auto zone/advanced,etc) You will need to give them your distributor for a core.. (save $)
New distributors come with a new coil & a new ICM.. although they are most likely rebuilt..
But you don't necessarily haft to buy a new distributor.. You can start by checking and testing your ignition coil & ignitor..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
No spark?
Check your ignition coil..
-Make sure ignition switched is turned to off position
-Remove the dizzy cap
- Disconnect the primary electrical connectors to the coil
- Using an ohmeter touch the probes and compare your results to the values listed.
Testing Ignition coil
Primary resistance 0.6 to 0.8 ohms
Secondary resistance 12.8 to 19.2 k-ohms
Also test your Ignitor (ignition control module)
- Check for battery voltage to the ignition module
- Check the ignition circuit and related componets if there is no voltage to the ICM check the circuit from the ICM to the battery. First check the ignition switch fuses (under the hood fuse box)
- If you get no voltage from the ICM.. Trace the wires down.. See if there is a break in the wire..
- Still no voltage? Your Ignitor has took a crap on you.. Time to replace the ICM.
DRAGANDB1
Aug 9, 2018 06:19 PM
carlos8
Jul 25, 2009 09:43 AM
b20turbocivic
Apr 25, 2008 08:54 PM
SI_niki
Jun 15, 2004 07:54 AM
