Amplified Subwoofer...Help
Old Oct 27, 2008 | 09:26 PM
mrchevez's Avatar
Default Amplified Subwoofer...Help
Searched.Didnt find anything
Have a sony headunit with 500watt amp and two 12inches sub
But i want to get rid of it, takes up to much space in trunk and i need it
So i found this 8" Amplified Nitrous-Oxide Inspired Subwoofer by bazooka
Any reviews/comments about it
Have a 98 integra. just want something small
is this one a good one?
link::
http://store.bazooka.com/NOS8A....aspx
or
there is the exact same one but not amplified
link::
http://carjamz.com/zen/index.p...=1755
should i just get this one and use old 500w amp but not sure if i can
because it says maximum is 300w
comments?
Modified by mrchevez at 10:32 PM 10/27/2008
Old Oct 28, 2008 | 01:24 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Amplified Subwoofer...Help (mrchevez)
Nice unit, But its going to make you want more in the long run. In a hatch it will fullfill the low end and give you a lil hump in the trunk. Try to go with a 10'' model and use a outboard amp.. But if room is a factor use a onboard amp version. IF you use your 500 watt amp please watch the gains or your voice coils will be toast in no time.
Old Oct 28, 2008 | 04:03 PM
95jdmej2's Avatar
Im a big fan of the bazooka 10' with the built-in amplifier. i have used them in boats, hatchback cars and trucks with limited space behind the seats and have had nothing but good results. doesnt take up to much space, easy to take out. Bazooka FTW!
Old Oct 28, 2008 | 10:57 PM
mrchevez's Avatar
Default Re: Amplified Subwoofer...Help (95jdmej2)
Thanks for both replys, helped alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">Nice unit, But its going to make you want more in the long run. In a hatch it will fullfill the low end and give you a lil hump in the trunk. Try to go with a 10'' model and use a outboard amp.. But if room is a factor use a onboard amp version. IF you use your 500 watt amp please watch the gains or your voice coils will be toast in no time.</TD></TR></TABLE>
thats the reason why i want the amplified amp because i dont want to blow the sub out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jdmej2 &raquo;</TD></TR><TR><TD CLASS="quote">Im a big fan of the bazooka 10' with the built-in amplifier. i have used them in boats, hatchback cars and trucks with limited space behind the seats and have had nothing but good results. doesnt take up to much space, easy to take out. Bazooka FTW!</TD></TR></TABLE>
you have pictures of when installed in your car?
Old Oct 29, 2008 | 10:38 AM
95jdmej2's Avatar
I dont have any pics. I havent put any in my car, all of them have been customers vehicles. But if you want i could send you dimensions of a 10" bazooka. I have one in the shop right now.
Old Oct 29, 2008 | 10:58 AM
twentyhurtz's Avatar
personally i have always worked at shops and competed in usaci and stuff and i've never been a fan of the powered subs but i would just get a small amp, mount to back of rear seat and get a small setup, 2 8" subs or something in a 10" tall x 30" long box or something and go with that, or even do a downfire setup that way you can pile stuff in there for the most part without worrying about damaging something
Old Oct 29, 2008 | 06:42 PM
mrchevez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jdmej2 &raquo;</TD></TR><TR><TD CLASS="quote">I dont have any pics. I havent put any in my car, all of them have been customers vehicles. But if you want i could send you dimensions of a 10" bazooka. I have one in the shop right now.</TD></TR></TABLE>
pleae can i have the dimensions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentyhurtz &raquo;</TD></TR><TR><TD CLASS="quote">personally i have always worked at shops and competed in usaci and stuff and i've never been a fan of the powered subs but i would just get a small amp, mount to back of rear seat and get a small setup, 2 8" subs or something in a 10" tall x 30" long box or something and go with that, or even do a downfire setup that way you can pile stuff in there for the most part without worrying about damaging something</TD></TR></TABLE>
that sounds pretty good
what about the Infinity Bass Link?
Old Nov 2, 2008 | 05:48 PM
95jdmej2's Avatar
I will get you some dimensions tomorrow when i get to work. I wouldnt suggest that infinity bass link. If i had to pick between the two i would go with the bazooka. Hands down, you would be happier.
Old Nov 4, 2008 | 06:08 AM
95jdmej2's Avatar
mrchevez, i got those dimensions for you. 22" long, 13" tall, 11" wide. These dimensions are for the marine one, but the regular one should be about the same size.
2290av6
Audio / Security / Video
Dec 31, 2007 05:30 AM
dk015
Jul 29, 2005 01:21 PM
Tanmt
May 13, 2004 06:40 AM
Looose_R
Jan 22, 2004 07:44 AM
