motor swap for dd
i posted this in 2 sec hope thats ok didnt know which was better
im thinking of puting a b16 in the car with less miles wile i build the b18 thats in it .my question is i wanna use my gsr tranny and was wonderin if this is all i need
and am i gonna need any new stuff. like a new ecu cause mine is chipped with chrome. if its not all ima need and i will run into some probs somewere please let me know this will be my first swap and i ant got very many friends that i think will help
i curintly have a gsr 97 motor and tranny
B16A 92-95 (SiR-II) Long Block
Price: $ 1100.00 Plus shipping and handling.
Availability: In Stock
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
- P30 ECU (Add $200)
i just need somin reliable to get to and from back to work and school starting in jan. ive been sprayin my gsr for some time now and have raced with or with out nitrous for a year as well. its now at about 105,000 miles
- Motor
- Intake Manifold
- Exhaust Manifold
- Injectors
- Fuel Rail
- Throttle body
- Alternator
- Distributor
if ur car is a obd1 the b16 will bot up to the gsr trans and everything will be the same just with less power and not sure about if u have to change the ecu but i would if i was u..
but the motor will drop in and hook up the same u already ahve the axels and stuff so u are all set just pull it out and drop the b16 in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotboxsi »</TD></TR><TR><TD CLASS="quote">afaik that setup looks good (but save the $200).
? what that means afaik</TD></TR></TABLE>
a = as
f = far
a = as
i = I
k = know
a = as
f = far
a = as
i = I
k = know
have you done a compression test and leakdown on your gsr?? maybe it just needs a re-tune.
before you waste your money on another motor do these things that wont cost you nething to see if your motor is "tired"
I'm sorry I didn't understand your last post, "its the motor" ? Not sure what you are referring to.
To reflash a chip: take it out of ecu, put it in a programmer which is connected to a computer via usb typically, on the computer in the software click READ and save it... That's your backup. Then load up the map for the engine you are putting in (you can download it online from places) and click WRITE, now that information is on the chip, reinstall in to ECU. Done.
Squallie
Jul 14, 2005 12:42 AM
