JDM HEADLIGHT Q
im not sure if i read it on here or what not but i was looking at the JDM one piece headlight...does anyone know if you can fit it on an USDM hatch? if so is there a write up on it?
In Japan, they came only only on the sedan. They won't bolt right in, but like anything, they can be modified to fit.
Only thing is though, whats so great about them?
the corner lens on the civic/crx sir slides/clips into the side of the jdm headlight as a perfect fit with 0 gaps.
basically the same as having a one piece headlight, only the good thing is it will fit right as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Dan »</TD></TR><TR><TD CLASS="quote">the corner lens on the civic/crx sir slides/clips into the side of the jdm headlight as a perfect fit with 0 gaps.
basically the same as having a one piece headlight, only the good thing is it will fit right as well.</TD></TR></TABLE>
thats what i was worried about...i mean it about 200 for them on PWJDM and i was thinking maybe someone has done them...who knows i might give it a shot and put a write up on it
i put them in on my 91 rex, the bulbs proved difficult to find, so i had to modify h4 bulbs to fit. they just dont seem that bright, even with the high beams on. it may be an aiming issue. the wiring wasnt too bad, rigged it on a relay system. sorry i havent had time to do a write-up or anything, but eventually ill start a build thread and post everything in it.
at this point, theyre more form than function, but with hid's in them it would be a good all around gig. they fit great and make the rex stand out among other crx's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Dan »</TD></TR><TR><TD CLASS="quote">the sir headlights wont fit your stock hood, or bumper, you need a jdm hood and bumper to fit, dont bother trying otherwise.
Modified by Turbo Dan at 6:24 AM 10/28/2008</TD></TR></TABLE>
well im planing a conversion but i want to stand out a bit...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iskate2 »</TD></TR><TR><TD CLASS="quote">i put them in on my 91 rex, the bulbs proved difficult to find, so i had to modify h4 bulbs to fit. they just dont seem that bright, even with the high beams on. it may be an aiming issue. the wiring wasnt too bad, rigged it on a relay system. sorry i havent had time to do a write-up or anything, but eventually ill start a build thread and post everything in it.
at this point, theyre more form than function, but with hid's in them it would be a good all around gig. they fit great and make the rex stand out among other crx's.</TD></TR></TABLE>
i must ask for atleast a pic to see what it looks like
If you want to stand out in a good way, why not source out a pair of EDM glass housing headlights with motorized height adjustment. They use H4 bulbs, and and much cooler than the jdm right hand drive aimed plastic headlights that use those stupid h4h bulbs.
Frog
Apr 6, 2004 04:38 PM
