99 civic cd radio doesnt play audio in my cb7.
okay it has been working fine for the last month. Today i bought tweeters and installed them the radio worked fine then while i was finishing up the sound just went out. The decks light and display is on and i can hear the disc spinning but there is no sounds. I triple checked all the wiring and still no sound. fuse is still good. I also disconnected the tweeters and still no sound. Also when it first went out i tapped the brake pedal and it came on for about a second or 2 then it cut off. someone please help!
Did you try starting your car, sounds like LOW voltage. It is possible you blew the output stage of your deck (internal amp) if its not voltage
Kirk R
Kirk R
HedgeCore
Audio / Security / Video
Jun 5, 2005 04:42 PM
acuraLSSE95
Nov 4, 2002 06:06 PM
