code 15 > Ignitor Output Signal
my cousin has an 89 LX sedan. im sure the motor is the same as the Base model DX. i did the MPFI and ran the 4 wires and switched the other 2 as suppose to. i even looked at my car to make sure.
i Swapped in an LS motor with an obd0 ECU (PR4) and reinstalled everything, i mean EVERYTHING!
came around to start the car after i double checked everything. car had no codes at first but after 1st crank, it gives a code 15. (Ignitor Output Signal)
my question is, did i have to depin anything from either side of the harness main plugs?? (circle ones)
How can i fix this?
BELOW IS PREVIOUS ISSUE THAT IS SOLVED (due to loose wire and busted cap)
alright. my 91 sedan has an LSV obd0 swap. i took out the harness out of my engine and used it to duplicate another obd0 harness. i DID NOT cut my harness apart. i just used pins to locate where each wires sit. so i finished another just like mines and i put that back on my car to see if it works. car cranks and whatnot but does not start. after a moment later code 15 comes up on that duplicated harness. so i take that out and put mines back on and same thing. cranks but does not start. then code 15 comes up. Ignitor Output Signal
i read around and people said its spark related.
i called a friend and they said its something inside the dizzy (dizzy is new about a year old) is it the module?
and my brother said he called ryan (rywire) and he said its the wiring somewhere on the cabin harness..so i checked the red/blue/green/yellow wires to my ecu and they are perfectly in its spot (wires for mpfi swap)..
i have school tmorrow and my car does not run. i need to get it fixed tonight or im forced to find a ride. any help tips would help. much appreciation.
Modified by My_EFsedan at 8:16 PM 11/2/2008
How can i fix this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACERX72 »</TD></TR><TR><TD CLASS="quote">its the dizzy i had the same problem, the ignitor inside the dizzy is gone.</TD></TR></TABLE>
any pix of how it looks like? the small silver like one with the wires in it? or the black one?
to be honest bro, i didnt want to mess with it. I know people told me to rebuild it , but i jsut decided to get a whole new one from getthozone, then i just got a cap and rotor fro mthe dealer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACERX72 »</TD></TR><TR><TD CLASS="quote">to be honest bro, i didnt want to mess with it. I know people told me to rebuild it , but i jsut decided to get a whole new one from getthozone, then i just got a cap and rotor fro mthe dealer</TD></TR></TABLE>
its already fixed. but thanks tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACERX72 »</TD></TR><TR><TD CLASS="quote">did you get it fixed? what was the problem</TD></TR></TABLE>
we fixed it again. now my cousins car runs great. problem..was...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">
From: I told you to wait in the truck in Texas, United States
If the old ignitor by chance says "OKI" on it,
Those were recalled by the factory
because the failure rate was so high..
I have had 2 fail on me which
prompted me to start carrying a spare in the glovebox.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">If the old ignitor by chance says "OKI" on it,
prompted me to start carrying a spare in the glovebox.</TD></TR></TABLE>
imma check that out if it says it. i remember reading that somewhere about the factory one having the failure rate being high..thanks for the info
punkracer
Aug 9, 2011 03:36 AM
SoFreshh
Dec 7, 2009 10:08 PM
