Suspension & Brakes Theory, alignment, spring rates....
'91 crx si performance alignment specs
Old Oct 27, 2008 | 02:39 PM
m_shake's Avatar
Default '91 crx si performance alignment specs
hi i have a 91 crx si and im lookin for a recommend alignment specs for all round use, mostly spirited driving and some track days. setup: b18c1 swap, koni gc 450fr 400rr, progress 22mm?? rear bar, skunk2 front camber kit, all mfactory rear suspension components, 205/50r15 azenis rt-615's on buddy club p1's 40ish offset, innovative new style traction bars/crossmember....think thats aboot it. ride height tire just aboot even with wheel opening. ooohh and poly bushings through out, and if it matters no a/c.
my guess on specs somewhere around 0 toe fr/rr 2.0 to 3.0 fr camber and 1.5 to 2.0 rr camber caster=???? considering my current alignment was done with string in my drive way( hey it drive straight now lol) anything will be an improvement.
thanks in advance guys
Old Oct 27, 2008 | 03:58 PM
Tyson's Avatar
Default Re: '91 crx si performance alignment specs (m_shake)
front toe can be 1/16 total toe out.
stay within stock caster.
and zero toe in the rear.
then actually drive your car at a safe performance area like a track or autox and learn to drive. otherwise, all that crap is useless.
Old Oct 27, 2008 | 04:18 PM
m_shake's Avatar
Default Re: '91 crx si performance alignment specs (Tyson)
thanks for the info tyson. so was i about right with the camber setup, i searched for quite a bit and thats all i could really come up with. yea totally need to track day....one of these days
Old Oct 27, 2008 | 04:19 PM
m_shake's Avatar
also the 1/16th total out in the front that wont kill tires very much will it? darty on the freeway? thanx
Old Oct 27, 2008 | 04:25 PM
Tyson's Avatar
you asked for a performance spec didnt you?
Old Oct 27, 2008 | 04:30 PM
m_shake's Avatar
im gonna need some cream for that burn myself
thanks tyson!
Old Apr 12, 2009 | 08:54 PM
zimsplat's Avatar
in my experience any toe out in the front is flat scarry...
preludeNApower
Suspension & Brakes
Aug 8, 2011 06:23 PM
Jon777
Suspension & Brakes
May 10, 2011 10:23 AM
ADAMnQuickRDX
Suspension & Brakes
10
Apr 9, 2009 05:27 AM
Mr.Saturn
Aug 4, 2004 02:14 AM
Reid
Jul 5, 2002 01:24 PM
