d15b is smoking
my dx started smoking out of no were ima drop a b16 in it soon i hav to do the mpfi conversion but wat do you think the smoking problem can be
do u think it could be the injectors are bad or i kinda put an extra quart of oil do u think that can be the reason y it smokes
if u can plz get back to me soon thanxs
Describe smoke. Is it White? Blueish? Black?
White usually means water. Meaning your HG is probably going bad.
Blue usually means oil. Meaning you rings, valve seals, or HG is probably going bad.
Black usually means fuel. Your running to rich. Probably bad o2 or related issue.
Now i said usually to all these possible issues. Meaning i gave a general answer to your general question about smoke.
