90-91 cluster into a 88dx?
Old Oct 27, 2008 | 01:52 PM
exz0n-.-'s Avatar
Default 90-91 cluster into a 88dx?
ok so i pulled a shroud and cluster outta a 91 at the junkyard, i wanted to put it into my 88 cause it has the tach and mine doesnt. i tried searching but i couldnt find anything?
is this possible? if so will it be hard and not worth it?
should i just try to find a plug and play one?
Old Oct 27, 2008 | 02:00 PM
sleepingciv's Avatar
Default Re: 90-91 cluster into a 88dx? (exz0n-.-)
it is possiable to put that cluster in your car did ya happen to get the plugs for it? If ya did ya just need to swap the wires its not hard. I have the pin outs for 88 and 91.
But if ya dont fell up to that a plug and play one will be alot better.
Old Oct 27, 2008 | 04:53 PM
therotaryrocket's Avatar
I put the 89 cluster in my 91, and matched all the wire colors. Most everything works, but now I get code 17 vss which I didn't get before, and my high beam indicator doesn't work. Also, that was a lot of wires, what a bitch, I wish I just waited to find the correct cluster that would just snap in place.
gl
Swe NitraM
12
Jan 21, 2012 04:17 PM
wongburger
Dec 13, 2009 08:39 PM
purple95
10
Mar 1, 2008 08:47 AM
91EF919
Sep 17, 2007 01:51 PM
Silroan
Jul 7, 2003 08:13 PM
