best header for b-swaped crx
Old Oct 27, 2008 | 10:20 AM
jdmrex90si's Avatar
Default best header for b-swaped crx
witch header would be best for a b-series swapped crx that is not to expensive but still makes good power and doesn't smake the ground over every bump like the DC 4-1 does on 1-1/2 inch drop. Basicaly i need a good header that makes good ground clearance on a b-series swapped crx
this is how my header looks it hits the ground atleast 4-times a day
Old Oct 27, 2008 | 10:43 AM
JScott3d's Avatar
Default Re: best header for b-swaped crx (jdmrex90si)
would you prefer a 4-1 or a 4-2-1? You will have better clearance with a 4-2-1 than a 4-1.
Old Oct 27, 2008 | 10:57 AM
jdmrex90si's Avatar
Default Re: best header for b-swaped crx (JScott3d)
4-2-1 becouse i know it will clear better then 4-1
Old Oct 27, 2008 | 01:16 PM
88SeeOurEx's Avatar
then just rock the DC 4-2-1's then your mid-range will be better too! oppose to top end with the 4-1's
Old Oct 28, 2008 | 08:45 AM
jdmrex90si's Avatar
but i really dont dig the DC brand header i wanted to see if there was more options out there that are better but still cheap
Old Oct 28, 2008 | 08:59 AM
jdmed3's Avatar
Default Re: (jdmrex90si)
Skunk2 is comin out with a 4-2-1 header that should clear pretty well i hear idk when there comin out but hopefully soon and they will flow really nice
Old Oct 28, 2008 | 09:35 AM
thorclark's Avatar
Urs looks like mind did. In the FAQ they show you how to get better Clearence with a omni test pipe.
Old Oct 28, 2008 | 09:41 AM
Crx Jimmy's Avatar
Default Re: best header for b-swaped crx (thorclark)
I have a real nice RS*R stainless 4-2-1 header for sale, it was over $500 new. make an offer. fits nice, way better looking than any DC header , made of THICK stainless tubing not the cheap thin crap dc uses.
jdmrex90si's Avatar
Default Re:
where at in the faq thread i couldn't find it, maybe i just skipped it or something
Old Oct 28, 2008 | 10:05 AM
FSTVTEC's Avatar
pmed you i have a nice jdm 5 zigen for sale clearance is great on my rex with this header
Old Oct 28, 2008 | 10:18 AM
efjones9's Avatar
Default Re: best header for b-swaped crx (FSTVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrex90si &raquo;</TD></TR><TR><TD CLASS="quote">where at in the faq thread i couldn't find it, maybe i just skipped it or something</TD></TR></TABLE>
i wana see that FAQ also
Old Oct 28, 2008 | 10:47 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: best header for b-swaped crx (efjones9)
Owning a good header and having a 4th gen means it will be dented.
Owning a crappy header and having a 4th gen means it will be dented.
What's your budget OP and setup?
Old Oct 28, 2008 | 11:18 AM
143MYVTECEF's Avatar
Default Re: best header for b-swaped crx (***$nyper)
This is the header that i will be purchasing. Its decently priced and has good ground clearance. He says the oil pan should be lower than the header
LogicMotorsports.com
Look up this user. He sells them
Old Oct 29, 2008 | 08:59 AM
jdmrex90si's Avatar
that header looks good but i dont now how that header looks like it will fit under the oil pan
Old Oct 29, 2008 | 02:40 PM
89civicdx's Avatar
in my civic
hytech replica
Vibrant Jspec header!
edit! Oh I think you need traction bar for these though to clear
Modified by 89civicdx at 3:52 PM 10/29/2008
Old Oct 29, 2008 | 02:55 PM
jdmboyef9's Avatar
I agree, the hytech replica sits way too low plus you need to modify the front crossmember to run it. DC is junk from my experience, it's too thin and rusts from the inside out...I also tried an FGK header before which was ok but my Mugen EF9 header has netted the best power and clearance so far...RS*R and 5ziggen are pretty good too.
Old Oct 29, 2008 | 05:16 PM
Furyof4's Avatar
Try this one&gt;http://www.hondamarketplace.co...64933
May even fit without too much denting of the crossmember. I have the edelbrock 2 piece which closely resembles that one, and I only had to dent to clear the 4-2 flanges. Without those in the way, like the one above, it would fit perfectly.
Old Oct 30, 2008 | 09:58 AM
jdmrex90si's Avatar
i like the vibrant Jspec header thats looks like it makes power and clears good,
And that header up there ^^^^ i was looking at its thread looks like it make real good clearance
Old Oct 30, 2008 | 10:09 AM
IT GUY's Avatar
Default Re: best header for b-swaped crx (Furyof4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">
May even fit without too much denting of the crossmember. I have the edelbrock 2 piece which closely resembles that one, and I only had to dent to clear the 4-2 flanges. Without those in the way, like the one above, it would fit perfectly.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">-will fit DA's and EF's with stock crossmembers</TD></TR></TABLE>
Old Oct 30, 2008 | 11:00 AM
jdmpnoy89's Avatar
Default Re: best header for b-swaped crx (IT GUY)
ctr header is also a good choice, plus it has a 2.5 inch collector
Old Oct 30, 2008 | 11:08 AM
EE2bitsk's Avatar
hy-tec replica is way too low.
i would personally go with the an-r, but its pretty expensive.
here is a pic.
http://memimage.cardomain.com//membe...n.com/...l.jpg
Old Oct 31, 2008 | 10:10 PM
ThisRightHere's Avatar
Skunk 2 4-2-1 sounds good
Old Nov 1, 2008 | 10:55 AM
BiG Chris's Avatar
yea im tired of the hang low it makes me roll almost stock hieght but im gonna cut mine up and shorten it to clear
Old Nov 1, 2008 | 03:00 PM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">
Quote, originally posted by Furyof4 »
Quote, originally posted by project dc2 »
Well there you go. Best option right now.
BeniRacing
17
Aug 22, 2007 08:16 PM
Rev Red
Mar 11, 2006 03:10 PM
kuki
Dec 24, 2004 02:36 PM
1c3a2m0
Mar 18, 2004 05:25 PM
essinem4130
10
Jun 27, 2003 09:24 AM
