96-00 Trunk Board Dimensions
I recently bought a EM1 but there was no trunk board at all. I was curious if there was a set of dimensions out there so I can make one? I did a search and nothing came up. Any and all help is greatly appreciated thanks!
It's kind of a weird shape. Not really square.
Okay, I finally got everything together.
This is a photo of the trunk board out of my '98 Civic coupe. They should all be the same. I imagine this would fit sedans too, and the rear half can be trimmed to fit a hatch. Just don't forget the handle hole at the bottom.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Varao »</TD></TR><TR><TD CLASS="quote">Thank you so much man you are a life saver!! Really good info I wish it could get into the FAQs section!</TD></TR></TABLE>
Lol.
Anyway, I re-traced mine onto some 1/4 plywood once, good to have the dimensions finally available though.
Lol.
Or, you could buy a template off of eBay and make the cover out of high density board.
http://shop.ebay.com/&Civic+spare+tire+cover+template
Hey any chance you still have the photo/dimensions available?
The link is no longer working for me. Thanks!
I've got a trunk floor I'm going to build once I get this heater issue fixed. I did get approx build measurements though. Hope this helps.
36'w x 8'-10' d
47'w
57'w
total length/depth 44'
36'w x 8'-10' d
47'w
57'w
And what would be the name of the material that makes up the board to purchase?
I gave the approx dimensions for a floor panel. If you were to cover the floor, that's a ballpark set of measurements for what it would be, though not including a cut out for the spare tire. I'm using mdf, you would be good with 1/2' or 3/4'. I would advise spraying the bottom,as in the side that rests on the floor, with rubber undercoat. This is in case you develop a leak in the metal floor itself. It'll keep your floor board from rotting out faster.
When I replaced mine, I bought a special kind of board from Lowes. It's made to go behind the tiles in bathrooms, so it's mold and mildew proof. Very easy to cut and work with, but it also supported my old JL 10W7-HO just fine...and anyone who has carried one of those knows it's heavy as a ************. Definitely the material I recommend for replacing the trunk board.
The photo is in the post you quoted. It works for me. Maybe try clearing cookies? Not sure why imageshack won't work for you.
From my end I can see the thumbnail of the photo that is in your post.
But when I click on this thumbnail, it sends me to the imageshack website and says the image is no longer available.
Here it is rehosted. Not sure why you couldn't get it to load.
http://imgur.com/ZrHqyEE
siblue_gzer
Apr 28, 2008 12:06 PM
WhtHatchBack
Jan 31, 2006 10:57 PM
dextR
Feb 23, 2004 06:54 PM
