Suspension & Brakes Theory, alignment, spring rates....
Question about Koni Yellow
Old Oct 26, 2008 | 11:55 PM
bopbop93030's Avatar
Default Question about Koni Yellow
Does this come with the brake line mount and the thing that holds the springs, in other words complete!
The stock shocks I don't have it anymore that is why I am asking.
If they do not come with it, will Koni include it even if you pay a little extra?
I really do not want to go with adjustable but is there a Koni Yellow that is not adjustable or a similar Koni.
Thanks
95 Accord
Old Oct 27, 2008 | 11:05 AM
Crazydave's Avatar
Default Re: Question about Koni Yellow (bopbop93030)
If I remember correclty you have to transfer the brake line mount from the stock shocks to the konis... so no..
how ever it is NOT essential to mount the brake line to the shock using the stock bracket... I suppose you could zip-tie it out of the way
Old Oct 27, 2008 | 12:49 PM
TunerN00b's Avatar
Default Re: Question about Koni Yellow (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">If I remember correclty you have to transfer the brake line mount from the stock shocks to the konis.
That is correct.
how ever it is NOT essential to mount the brake line to the shock using the stock bracket... I suppose you could zip-tie it out of the way</TD></TR></TABLE>
I used 2 zipties per shocks. 1 wrapped around the shock body about where the stock bracket was located (pulled very tight), and another looped around the brake line and 1st tie. This way, I could leave the tie wrapping the brake line slightly loose, to allow the line to slide through the tie as the suspension moves.
2 years, no issues.
Old Nov 4, 2008 | 08:37 AM
Default Re: Question about Koni Yellow (TunerN00b)
How do you adjust the rears? remove the shock or is there is a **** in the body or shaft like the fronts do?
From what I hear is that you have to remove the shocks in the car before you can adjust it.
Is this true?
Old Nov 4, 2008 | 11:48 AM
hawjboi's Avatar
adjusting the koni yellow rears is the same as adjusting the fronts...with a ****...if you dont want the adjustables koni also offers the koni reds....
bboysake
Suspension & Brakes
May 6, 2010 01:35 PM
crxsleeper210
Feb 17, 2008 01:40 PM
RSZero1
Suspension & Brakes
Mar 30, 2007 12:08 PM
VTECAcuraGSR
12
May 2, 2005 08:02 PM
speedevo
Oct 28, 2003 01:59 PM
