Will 99 ITR REAR seats fit in a 99 Civic Si?
There's a way of doing it, I believe you need to take the frame out of the Stock rear seats and swap them with the Integ ones, and to eliminate the gap between the bench and the rear seat you postion the bench farther back.
As for going in a Si im not sure, but it appears the rear seat portion won't even fill up the space because the Integra's rear seats are narrower than a Si, maybe you could just use the bench? but then there would be no point in that now would there.
imptricer
Aug 22, 2011 09:49 PM
