is tuning absolutely nesesary c.r. increase..?
Old Oct 26, 2008 | 06:08 PM
museboy07's Avatar
Default is tuning absolutely nesesary with c.r. increase..?
I'm rebuilding my d16y8 with high compression zc dome pistons, apexi 1.5mm head gasket, and all oem bearings, etc. I have figured around 11.5-1 c.r. give or take a little bit. With this i also plan on running 93 octane and an aftermarket ignition system (msd). With everything else stock will it be okay to run it without a tune?? I plan on going with a stage 2 crower cam later on but finances won't allow everything right now. So is it ok to run the engine with 11.5-1 compression untuned?? Whenever i get the cam installed ill get it tuned but it'll take a couple months to afford that. So will i be ok or will my engine detonate itself to pieces??
Modified by museboy07 at 7:21 PM 10/26/2008
Old Oct 26, 2008 | 06:37 PM
t0p_sh0tta's Avatar
Default Re: is tuning absolutely nesesary with c.r. increase..? (museboy07)
Could you do it? Probably, but you won't feel the power increase without a proper tune. Do it right, or don't do it at all. Tuning can be done without dropping major coin.
Old Oct 26, 2008 | 06:56 PM
museboy07's Avatar
Default Re: is tuning absolutely nesesary with c.r. increase..? (t0p_sh0tta)
ok since im running obd2a what engine management do you suggest that won't cost an arm and leg?
Old Oct 26, 2008 | 07:05 PM
Nic's Avatar
Nic
I dont think a tune will be needed untill your drop in that cam but even then your stock computer should handle that setup pretty easy. Timing might be your only issue with that much compression. If your gonna get a cam in the near future I would not get it tuned just yet...just dont beat the hell out of it on a daily basis and you will be. Once you get that cam and adjustable cam gear get it tuned. good luck on the build
Old Oct 26, 2008 | 07:11 PM
museboy07's Avatar
Default Re: is tuning absolutely nesesary with c.r. increase..? (Nic)
Any ideas what i could do for timing? I could install an adjustable cam gear on it when i build it before i put the cam in but im unsure on how much to adjust??
jdmcivic2fast
Oct 31, 2011 12:18 PM
josephcmiller2
Engine Management and Tuning
Apr 26, 2011 06:12 AM
paopao
Jan 13, 2006 09:42 PM
carbonell
Apr 2, 2004 08:11 AM
Superhatch
Apr 27, 2003 03:50 PM
