Turn signals on my 3g integra dont work!!!!!!!!!!!!
can ne one help my turnsignals on my 96 gsr is not workin I checked the fuse underdash and the one in the hood their still good. also check the relay under the dash and its fine also. its not the clicker( the black piece with headlight switch) cuz i took off and plugged it into my other teg and it works fine? NE other solution or ideas on whats wrong ? the hazard light works they light up but they dont click( signal) back one also light up but doesnt blink either
HELLLLPPPPP MEEEEE!!!!!
no clicking you say. check your relay.
Which relay you ask? Go into another honda and turn on the hazards. You hear that clicking, its coming from the relay right by the fuses. Swap out the one from the working honda into yours and see if your blinkers work.
btw, i learned this from http://www.hyperblinker.com
shameless plug.
shameless plug.
damn, i just re-read your tread and i pretty much repeated what you said.
(You should use more commas and periods next time
Since you said it wasn't the relay (noise maker), your hazard button seems to be plugged in, you checked the fuses already, the only thing i can think of is an exposed wire somewhere. Not much more that i can think of, but try asking the people in audio/security for some help.
[Modified by Mt3c, 11:37 PM 7/29/2002]
) Since you said it wasn't the relay (noise maker), your hazard button seems to be plugged in, you checked the fuses already, the only thing i can think of is an exposed wire somewhere. Not much more that i can think of, but try asking the people in audio/security for some help.
anthonylee29
Jan 29, 2006 07:40 PM
