swap or make it clean
Old Oct 26, 2008 | 02:57 PM
spens 91 Ef's Avatar
Default swap or make it clean
i got 91 civic hatch it has a d15b2 with a bad clutch not alot of power. im trying to decide whether to try to do a swap with around 1100$ or just make my car nice and clean. i want to do a swap to make it faster but if i do that thats all i can pretty much if i do that i wouldnt have money for paint rims or other accessories. its also my first car and would be my first swap so its a hard decision.
need some help with my decision as you can see it doesnt look all that nice both the doors were spray painted, ripped seats, scratched up rear bumper, bad taillights
Old Oct 26, 2008 | 03:00 PM
IndySporty's Avatar
Make it clean, 1100 bucks goes a lot further in looks than it does in motors.
Old Oct 26, 2008 | 03:05 PM
Default Re: (IndySporty)
ya it exactly i dont even think i could do a swap for that much i could have a bit left over after for some headers and crap thanks for the input
Old Oct 26, 2008 | 03:13 PM
sleepingciv's Avatar
Default Re: (spens 91 Ef)
could do a mini me swap its cheap, and still have money for a header and stuff
Old Oct 26, 2008 | 03:16 PM
Default Re: (sleepingciv)
thats another thing i have been thinking about give me a lil more power
Old Oct 26, 2008 | 04:07 PM
leroyb's Avatar
just make it clean you can always run it to good deals on a motor later down the road
Old Oct 26, 2008 | 04:12 PM
efsublime's Avatar
it almost looks like you have positive camber in the rear, in those pics.
Old Oct 26, 2008 | 04:17 PM
Default Re: (efsublime)
its a bent rear crossmember im gonna get fixed at a body shop soon, i wish it was only that lol
Old Oct 26, 2008 | 04:18 PM
My_EFsedan's Avatar
Default Re: (leroyb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leroyb &raquo;</TD></TR><TR><TD CLASS="quote">just make it clean you can always run it to good deals on a motor later down the road
\</TD></TR></TABLE>
if you where around me (although im here in SJ), ill make your car clean to your desired beauty. and 1100 is more than enough!
im like show and go. we just picked a perfectly running DA for 400 w/ a front end dmg and it has everything i need to swap into my cousins car. then i already mounts for B to EF from the junkyard for $16!! so. thats about 600 total including exhaust.. just be a bit patient and a great deal will come around like it did for us.
i'd do a swap first and have that beater sleeperific look for temporary. cause making a car look good can be done as you go..IMO. i did motor 1st then looks.
Old Oct 26, 2008 | 04:46 PM
Eric_H's Avatar
id do body first. thats what im doing, i have damage to the hood headlight bumper and fender on the passenger side, as well as a little bit of rust. im taking car of all that, paint, then come spring im doing a motor swap from the b2 to a d16a6.
Old Oct 26, 2008 | 05:16 PM
redef90si's Avatar
Default Re: (Eric_H)
i gotta go with fixing the motor first if i were you i'd:
drop in a si tranny and new clutch($300-500)total
that way you could drop in a d16a6 a little further down the road yet you'd still have a new clutch and a close ration tranny;plus some money for "looks" just my 2 cents though
Old Oct 26, 2008 | 06:00 PM
rayrex91's Avatar
body and paint.thats what i did 1st.
Old Oct 26, 2008 | 06:09 PM
EFinawesomeman's Avatar
Default Re: (rayrex91)
Replace your bad clutch, that engine will probably end up saving you money gas wise in the long run. Work on the looks.
Old Oct 26, 2008 | 07:57 PM
kojack_0's Avatar
Default Re: (EFinawesomeman)
why not get the car running right first, replace clutch and what ever mechanical malfunctions you got, then see where you wanna go from there. ive had that rear 1/4 rust covered in aluminum tape since i got my car, but its running smooth, quiet and strong, heat working for the winter, fluids changed, etc.
i like to work on my cars inside out. just my opinion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My_EFsedan &raquo;</TD></TR><TR><TD CLASS="quote">
im from sj too. which junkyard you go to?
Old Oct 26, 2008 | 08:20 PM
DOHCED8's Avatar
Default Re: (kojack_0)
id do a ZC swap.. u can get just a motor for pretty cheap. pick up an OE exedy clutch for less than $100... do a little wiring and pick up an ecu from a junkyard.. and still have some money to do things 2 make it look decent
Old Oct 26, 2008 | 08:36 PM
badluckrex's Avatar
Default Re: swap or make it clean (spens 91 Ef)
boostin sohc's has been proven power.. u could scrounge 2gether a setup within 1100
Old Oct 26, 2008 | 08:56 PM
My_EFsedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kojack_0 &raquo;</TD></TR><TR><TD CLASS="quote">
im from sj too. which junkyard you go to?</TD></TR></TABLE>
monteray and commercial. then theres trade zone alot of other peoples import go. but i havent been to any in awhile
Old Oct 26, 2008 | 09:07 PM
kojack_0's Avatar
Default Re: (My_EFsedan)
haha san jose!! i thought you meant south jersey.
Old Oct 26, 2008 | 09:33 PM
hatcht9x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kojack_0 &raquo;</TD></TR><TR><TD CLASS="quote">why not get the car running right first, replace clutch and what ever mechanical malfunctions you got, then see where you wanna go from there. ive had that rear 1/4 rust covered in aluminum tape since i got my car, but its running smooth, quiet and strong, heat working for the winter, fluids changed, etc.</TD></TR></TABLE>
x2
monteray and commercial. then theres trade zone alot of other peoples import go. but i havent been to any in awhile</TD></TR></TABLE> what/where is trade zone?
Old Oct 26, 2008 | 09:39 PM
stunn'd's Avatar
There is nothing funnier than wasting fools in old fwd honda's. I say build the ish outta it and leave it ugly.
Old Oct 26, 2008 | 09:49 PM
therotaryrocket's Avatar
I think you'd be spending $1100 on a fair paint job, that's including body work. You also don't want to paint over spray paint, so some areas would have to be stripped. If you change colors than you would want to paint the door jambs which also adds cost.
My suggestion....go buy some good tools and learn all you need to work on it yourself. gl
Old Oct 26, 2008 | 10:29 PM
Alex_C's Avatar
Totally agree with Kojack.
Put that money into having a good car. A mechanically sound car is way more useful that a bucket of bolts that looks great or mediocre performance in a shitbox. Like a bunch of people said, 1100 bones isn't gonna do much, properly.
Your car doesn't appear to have much rust on it. Body work and paint can probably wait. Project cars can take years to complete on a budget. Knowing everything about your car will save you huge amounts of money and make upgrading it way more successful and therefore much more enjoyable as a hobby.
Old Oct 26, 2008 | 10:46 PM
C_R_X_V_T_E_C's Avatar
Default Re: (Alex_C)
i def. agree you should make the car reliable, but i.m.o. swap it or do a mini-me .... sleepeeeerrr.
fix your clutch!!!
or you could;
rattle can the fender
just get some stock headlights, a v-tec head, an exhaust, an intake mani, and a header.
im assuming is dual point.... so you would prolly have to do some wiring with either option.
Modified by C_R_X_V_T_E_C at 1:54 AM 10/27/2008
Old Oct 26, 2008 | 10:51 PM
My_EFsedan's Avatar
Default Re: (hatcht9x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatcht9x &raquo;</TD></TR><TR><TD CLASS="quote">
x2
what/where is trade zone?</TD></TR></TABLE>
milipitas
Old Oct 26, 2008 | 10:56 PM
my_efsedan. you should cut out the webbing so your hood doesnt sit like that... i looked at your pics, where'd you get your front lip from?
SORRY FOR THREAD JACKING...
