How do you adjust headlight beam height on 6th gen?
I searched and only found how to remove the headlight not how to adjust how high or how low it is pointing. My right headlight is slightly off and aims at on coming drivers so I would like to reduce the beam's height. Does anyone know if there is a way?
Diagrams/pics would be awesome
look straight down on the back side of the headlight assembles and you will see two holes that will accept a long #2 philips head screwdriver (at least a 5in), one adjusts up and down the other is left to right.
Park the car on level ground about 10 feet away from a brick wall or something with horizontal and vertical lines on it. It's much easier to adjust that way.
Ichigo
Mar 23, 2007 07:18 AM
Saki
Jun 7, 2004 12:28 AM
accordblk
Dec 10, 2002 10:57 PM
