I NEED HELP RIGHT NOW PLZ!!!
Old Oct 26, 2008 | 11:02 AM
jdm27ef's Avatar
Default I NEED HELP RIGHT NOW PLZ!!!
ok so i have 90 civic si, i drive it 32 miles everyday, and i havent changed my oil for 2 months now im pretty sure i need to change it, imma change the oil later. while drivng to work this morning, i shifted to second then my car died. tried to start it again i cant hear the car cranking, i only hear my starter, whats seems to be the problem with my car pls help!!!
Old Oct 26, 2008 | 01:23 PM
honda.lioness's Avatar
Default Re: I NEED HELP RIGHT NOW PLZ!!! (jdm27ef)
The following is a very good site for troubleshooting no-start situations with Hondas:
http://www.tegger.com/hondafaq/faq.html#startrun
Old Oct 26, 2008 | 01:52 PM
143MYVTECEF's Avatar
Default Re: I NEED HELP RIGHT NOW PLZ!!! (honda.lioness)
So the car was cranking but not turning over? Any back fire? Check engine light? First thing id check is the distributor, then fuel relay, then battery (related fuses). These are usually the culprit for our cars. Especially if they've never been replaced.
Old Oct 26, 2008 | 02:18 PM
jdm27ef's Avatar
Default Re: I NEED HELP RIGHT NOW PLZ!!! (143MYVTECEF)
yeah i had that problem fix like 4 months ago, main relay are good, new dizzy, new battery, can it be the alternator too??
Old Oct 26, 2008 | 06:40 PM
EF_9's Avatar
yes it can be the alternator, but just in case borrow a friends main relay to be sure cuz this happened to me 1,000 of times and check the dizzy
Old Oct 26, 2008 | 07:10 PM
zrickety's Avatar
you hear the starter but no cranking? sounds like the timing belt broke
Old Oct 26, 2008 | 07:30 PM
ivanson's Avatar
yea check your timing belt. might of skip a tooth ie broke.
Old Oct 26, 2008 | 07:52 PM
KRock459's Avatar
Does th motor sound like its cranking but has no compression, as if the plugs where out (fast crank)? That would be a timing belt as zrickety mentioned. If you hear the solenoid click but no crank, thats the starter......or ultra low voltage. Check to see how bright the headlights are, could have lost your alt., but your car will usualy surge for a few minutes and then die.
Kirk R
Old Oct 26, 2008 | 10:17 PM
therotaryrocket's Avatar
the distributor won't turn if the timing belt is broken, take off the cap, crank and observe.
Old Oct 26, 2008 | 10:28 PM
C_I_V_I_C_V_T_E_C's Avatar
Default Re: (therotaryrocket)
fuse maybe? relay maybe? Do you get spark? any codes? we need more info
Old Oct 28, 2008 | 10:42 AM
jdm27ef's Avatar
Default Re: I NEED HELP RIGHT NOW PLZ!!! (KRock459)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRock459 &raquo;</TD></TR><TR><TD CLASS="quote">Does th motor sound like its cranking but has no compression, as if the plugs where out (fast crank)? That would be a timing belt as zrickety mentioned. If you hear the solenoid click but no crank, thats the starter......or ultra low voltage. Check to see how bright the headlights are, could have lost your alt., but your car will usualy surge for a few minutes and then die.
Kirk R</TD></TR></TABLE>
yeah its crankng fast sound like the spark plugs are out, timing belt are brand new i just got like 3 months ago, starter are new also got it from honda, dizzy are new from honda, alternator i got it from junk yard but i dont think its the alternator cause if it is ill see a battery check on the dash. can it be the spark plug wires
Old Oct 28, 2008 | 10:44 AM
jdm27ef's Avatar
Default Re: (EF_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_9 &raquo;</TD></TR><TR><TD CLASS="quote">yes it can be the alternator, but just in case borrow a friends main relay to be sure cuz this happened to me 1,000 of times and check the dizzy</TD></TR></TABLE>
yeah the main relay is good just got it from junk yard and i can hear it clicking, dizzy is brand new from honda and starter too, how do i check if my fuel line is clugged and how can i bleed the fuel out
Old Oct 28, 2008 | 10:45 AM
Eric_H's Avatar
could possibly be fouled spark plugs. try the simple maintenance stuff first, such as plugs and wires. move on from there.
Old Nov 1, 2008 | 04:18 AM
EF_9's Avatar
Default Re: (jdm27ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm27ef &raquo;</TD></TR><TR><TD CLASS="quote">
yeah the main relay is good just got it from junk yard and i can hear it clicking, dizzy is brand new from honda and starter too, how do i check if my fuel line is clugged and how can i bleed the fuel out</TD></TR></TABLE>
fuel naw man.. check for ground too i remember my car would not start and realized it was just one wire not grounded so yeah try that. junk yard main relays may be bad. if not i do say check spark plugs and check inside to see if theres water or oil. LMK
Old Nov 1, 2008 | 09:21 PM
KillBot's Avatar
yeah its crankng fast sound like the spark plugs are out</TD></TR></TABLE>
Like there is no compression?
Your hatch is not swimming in a giant pool of oil, is it?
Old Nov 1, 2008 | 11:41 PM
saikouEF8's Avatar
battery cables loose frayed or broken under the loom?
Old Nov 2, 2008 | 09:42 AM
jdm27ef's Avatar
Default Re: I NEED HELP RIGHT NOW PLZ!!! (KillBot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillBot &raquo;</TD></TR><TR><TD CLASS="quote">
actually i think im out of oil i avent change my oil for 3 months driving 32 miles every day back and forth
stiffinEK
Jan 25, 2009 01:08 PM
queensny
Feb 13, 2008 10:26 AM
antiricer
13
Jan 20, 2007 02:52 PM
kenshin_x
Nov 26, 2005 11:34 AM
