just got new brakes and they sqeal??
Old Jul 29, 2002 | 04:58 PM
asdfg1234's Avatar
Default just got new brakes and they sqeal??
i just got new power slot rotors and new pads im not sure but there good ones not cheap, i was wondering if it was normal for them to sqeal while they are still new, i had them in for like 20 miles and they just started to sqeal for about the last 5 miles. please write back asap thanks
Old Jul 29, 2002 | 05:14 PM
shermanyang's Avatar
Default Re: just got new brakes and they sqeal?? (asdfg1234)
didn't the kit come with some orange or whatever color anti-squeal lub? even the cheap kits come with those.
Old Jul 29, 2002 | 10:07 PM
tararan's Avatar
new pads always squeal, mostly the expensive kind... i rarely see new pads not squeal at all....
Old Jul 30, 2002 | 07:26 AM
LTB420's Avatar
Default Re: just got new brakes and they sqeal?? (tararan)
once your brakes break in the squal will go away.
Old Jul 30, 2002 | 10:58 AM
IlikeTODA's Avatar
Yes, it should go away, but my question is did you use shims? If you don't have shims on them then you might want to pull them back apart and get some anti squel spray for the back of the pads.
I have always been told the squeal is caused by the pad moving bad and forth inside the caliper very fast. The spray doesnt let it move and if it does it has a sort of "cushion".
Thanks, J
Old Jul 30, 2002 | 12:55 PM
kinesistech's Avatar
Vibration is what causes noise. Brakes all around the world make noise. We Americans whine about it while everyone else just understands it. If you used brake lube, it would be quiet. Some brake pads are harder than others and may help contribute noise, racing brakes just squeak more. Get over it.
Old Jul 30, 2002 | 02:11 PM
asdfg1234's Avatar
Default Re: just got new brakes and they sqeal?? (kinesistech)
yea i used the anti squeal stuff, the only reason im conserne is because it sounds like the sound when brakes get worn out. it only sounds like its comin from the driverside. how long does it take for the sweal of new brakes to go away?? it looks like on the rotors either the top or bottom of the rotor is getin more use for some reason, just on the driverside????????????????/ pleeease helppp
Old Aug 5, 2002 | 03:41 PM
1hotintegra's Avatar
its been about 400-500 miles, there still squealin. they sometimes squeal when i dont even hit the brakes like as if they were worn out. what could it be?????? its startin to **** me off
Jahba
Suspension & Brakes
Sep 21, 2011 06:41 PM
.Ry
Jul 2, 2005 04:28 AM
endlessdv
May 17, 2004 07:44 PM
asdfg1234
Aug 5, 2002 03:40 PM
