car idles low at start up.
Old Jul 29, 2002 | 04:52 PM
ILOVEGIRLS's Avatar
Default car idles low at start up.
is there a reason? should i adjust the screw to raise it? what is it suppose to be at start up any ways? thanks.
Old Jul 29, 2002 | 05:47 PM
mskibbz-T's Avatar
Default Re: car idles low at start up. (ILOVEGIRLS)
If it is just when you start up, check your idle air control valve on your throttle body. That valve controls your idle during starts and cold weather, so that your car warms up quicker. Your idle should be around 650-750 I believe, you can fine tune it via the screw on your throttle body. Probably should check out your idle air control valve just to be sure though, mine went all whacky a few months ago..
Old Jul 30, 2002 | 04:53 PM
ILOVEGIRLS's Avatar
Default Re: car idles low at start up. (mskibbz)
thats what i was thinking. my car starts up and its at about 700. i thought it was suppose to idle higher than that til the car warms up.
Old Jul 30, 2002 | 08:35 PM
ILOVEGIRLS's Avatar
Default Re: car idles low at start up. (C5_ALLMOTOR)
no smoke. just started doing it a few weeks ago. btw, LS vtec. has been running for over 2 years now with no problems.
Old Jul 30, 2002 | 11:49 PM
Cramerox's Avatar
there is a sensor that controls this isnt there? i believe its near the TB where the colant line goes to.
Old Jul 31, 2002 | 10:59 AM
Some Gook with a DC2's Avatar
Default Re: car idles low at start up. (Cramerox)
both integras that ive owned idled around 1.5 rpm when i first start it during the day, when i start it later when its a little warm it idles around 850
Old Jul 31, 2002 | 02:43 PM
ILOVEGIRLS's Avatar
Default Re: car idles low at start up. (Some **** with a DC2)
hmm..ill turn it up and see what happens. thanks.
duballstar
Aug 8, 2012 09:54 AM
TearSDMF89dx
Jan 3, 2012 04:31 AM
ricknbird350
Aug 24, 2007 06:12 AM
b20integrapower
Jan 24, 2006 02:03 PM
