Lighting HID/Xenon kits, Retrofits and Associated Topics
Depo clear fog light installation upgraded with HIDs.
Old Oct 26, 2008 | 08:18 AM
chickenwing's Avatar
Default Depo clear fog light installation upgraded with HIDs.
well since the depo's come with low output 55 watt bulbs. Why not upgrade the bulbs when installing them.
depo light with glass clear lenses
bulb comparison
drill hole in back plate
wiring up the sucka
heat shrink
Old Nov 7, 2008 | 04:50 AM
JDMCRX's Avatar
Default Re: Depo clear fog light installation upgraded with HIDs. (chickenwing)
Hows the actual light output?
Old Nov 7, 2008 | 05:47 AM
Default Re: Depo clear fog light installation upgraded with HIDs. (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">Hows the actual light output?</TD></TR></TABLE>
these are foglights so the output is mostly in front and to the left and right edges on the road. Very good compliment to the hid low beams as if fills in the needed area.
Old Nov 13, 2008 | 03:08 PM
rip94delsol's Avatar
nice writeup
I got the same crimper, but what i want to know is where do you get your connectors?
Old Nov 13, 2008 | 03:34 PM
Default Re: Depo clear fog light installation upgraded with HIDs. (rip94delsol)
Originally Posted by rip94delsol
nice writeup
I use to work in the industry and these are just leftovers.
What do you need exactly?
Old Nov 13, 2008 | 06:29 PM
uniseriate's Avatar
Fog lamps aren't needed with low beams during clear weather. You are just making your long range night vision worse with them on. You get a lot of foreground illumination in your field of view but all that will do is make your pupils constrict slightly, which ultimately decreases your long range night vision. The foreground illumination is essentially useless because you can't react to what you see in enough time.
Shoving HID burners into optics meant for halogen bulbs is also going to create a lot of glare for other drivers. Regular fog lamps are bad enough using just a 900 lumen H3 bulb due to most fog lamps having poorly designed optics. With more than three times the lumen ouput, these HID burners in your lamps are going to be a safety hazard.
Old Nov 14, 2008 | 03:02 AM
I mainly need oem type connectors, if you know of a place please let me know!
Old Nov 16, 2008 | 05:25 AM
you mean H4/9003 connectors for the headlight bulbs?
byc_cb7
Jun 20, 2009 07:20 AM
SFlCrx
May 17, 2006 07:22 PM
CivicVX94
Jan 26, 2006 09:20 PM
DaKINE-Ek
Jan 2, 2005 02:53 PM
