91 Civic no brake lights or turn signals??
Old Oct 26, 2008 | 04:44 AM
vitaminb18a1's Avatar
Default 91 Civic no brake lights or turn signals??
No power to brake switch or turn signal switch, is there a plug on the fuse box for this maybe that just came unplugged
Old Oct 26, 2008 | 05:07 AM
sleepingciv's Avatar
Default Re: 91 Civic no brake lights or turn signals?? (vitaminb18a1)
there is a fuse in the fuse box for those i dont remember the fuse number but check your fuses
Old Oct 26, 2008 | 05:22 PM
awdracer6's Avatar
I do know that if you dont have the plug for the flashers plugged in then they will not work... The plug im talkin about is the one on the plastic cover that surrounds the speedo and stuff... did you take that off maybe??
Old Oct 26, 2008 | 05:29 PM
IndySporty's Avatar
Default Re: (awdracer6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdracer6 &raquo;</TD></TR><TR><TD CLASS="quote">I do know that if you dont have the plug for the flashers plugged in then they will not work... The plug im talkin about is the one on the plastic cover that surrounds the speedo and stuff... did you take that off maybe??</TD></TR></TABLE>
That one doesn't have anything to do with the brake lights, they have thier own fuse in the underdash fusebox... but in addition to checking the 4-way switch (just try one out of another EF) on the blinkers, you also should check the underhood fuse for the 4-ways
Bump for a Fayetteville area dude Freaky Friday next Friday.
Old Oct 26, 2008 | 05:51 PM
dacrxguy's Avatar
the brake and horn are in the same circuit so check if your horn works if not start off by checking if your fuse is blown the fuse is the under the hood on the passenger side standing in front of the passenger wheel it is the 2nd going from bottom to top 15a one on the left side of the fusebox
Old Oct 26, 2008 | 05:55 PM
awdracer6's Avatar
Default Re: (dacrxguy)
ahh... i saw turn signal and thought about that plug..
rak511
Jun 4, 2014 09:30 AM
djsimm89
19
Feb 24, 2009 11:17 AM
MadCityLude
Oct 20, 2006 11:54 AM
Matt00
Feb 27, 2006 02:16 PM
sonofa
Jan 3, 2006 11:27 AM
