lacking power from stop to 3 grand
Old Oct 26, 2008 | 04:12 AM
turbozcteg's Avatar
Default lacking power from stop to 3 grand
just wondering if anyone else has this problem
engine is a b18b1 in a 95 ls integra
my problem is when i take off from a light it seems the engine is strugiling up till about 3 grand and then it just shoots off like a bat out of hell
ive adjusted timing and adjusted fuel pressuer and cant figuer it out
im wondering if its bad plug wires or something causing a ignition break momentairly
also i have a 4to 1 headder with a flat runner in one pipe and wondering if that could cause a problem too
Old Oct 26, 2008 | 04:54 AM
felixjr18's Avatar
Default Re: lacking power from stop to 3 grand (turbozcteg)
I feel like I have that same problem... My motor is the b18a1. Starting from first gear is fine but power really kicks in at around 3 and in anyother gear theres nothing untill 3.. Never had vtec before but that's what it sounds like it does lol
Old Oct 26, 2008 | 05:07 AM
kronikSLOW's Avatar
could be that flat runner and possibly an o2 sensor. hows your gas milage.
Old Oct 26, 2008 | 05:18 AM
felixjr18's Avatar
Default Re: lacking power from stop to 3 grand (kronikSLOW)
My gas mileage kind of sucks actually.. I drove from westerville to marion raceway which is a 47.5 mi drive and was at almost half a tank or less I only did a couple runs down the strip but still? Mods include ebay headers downpipe hi flo cat and exhaust cold air intake.
Old Oct 26, 2008 | 08:51 AM
omnirage's Avatar
Two things;
1. No power before 3000-ish RPM? SURPRISE! That's because you're driving a Honda. Rev it!
2. Unless we've got some extensive work done, face it...we don't take off like a bat out of hell, our little b18 is innately slow. Beats any domestic commuter though doesn't it!
Old Oct 26, 2008 | 08:58 AM
felixjr18's Avatar
Default Re: lacking power from stop to 3 grand (omnirage)
True I guess I jus need more power haha..
Old Oct 26, 2008 | 10:12 AM
xplosion79's Avatar
I think it's the lack of a thing called....torque
Something that doesn't exist in a honda, lol.
Old Oct 26, 2008 | 12:28 PM
turbozcteg's Avatar
Default Re: lacking power from stop to 3 grand (xplosion79)
no cause i have a 92 integra also with a b18a and it takes off the way it seems it should
its not a lack of torque
its like trying to take off with only 3 cylinders working and at 3 grand the 4th kicks in and it runs fine
i mean for christ sake i got beet off the line by a geo storm
but as soon as i hit 3300 i shot by him with the quickness
Old Oct 26, 2008 | 07:02 PM
wugawug's Avatar
i get this problem also, in my 95 ls, execpt, i dont get anything until 4 grand, but when its cold and idles at 2 grand or 1.5 cause the cold start's up, then its fine, but now, it barley gets out of its own way, but the car was fine a month ago, i've only added an N1 cat back, test pipe, and short ram intake, my O2 is fine, i get good gas mileage, i dont get any smoke, only in the mornings (white, condensation in exhaust pipe, and a tiney bit of coolant), i checked my IAC, did a valve adjustment, ect. if you find whats causeing this, lemmie know
Old Oct 26, 2008 | 08:11 PM
kronikSLOW's Avatar
Default Re: lacking power from stop to 3 grand (wugawug)
whats your warm idle speed at. is your iacv clean. are your valve covers leaking. is your intake manifold gasket good. is your throttle body gasket good. is your pcv valve clogged. clean iacv and pcv valve with carb cleaner. is your cat clogged. any cels.
ruffrhyder's Avatar
Sounds like an ignition problem, my civic did that right before my ignition coil took a crap on me and left me stranded in 110 degree weather. From a stop, the car would take forever just to get rolling. I mean, its like I wasn't even pressing the gas and was just letting off the clutch until I reved up. It was like there was no power at all, but as soon as I reved it past 3500 or so rpm the car would accelerate like as if I was launching from 3500 rpm, just like you guys are saying.
Old Oct 26, 2008 | 08:24 PM
TweakIntheCO's Avatar
Default Re: (ruffrhyder)
plugs, wires, coil, cap.
Old Oct 26, 2008 | 08:31 PM
letsdrive's Avatar
cap and rotor. either clean em or buy new ones. would explain the lack of power down low and the bad gas mileage.
Old Oct 27, 2008 | 02:46 PM
turbozcteg's Avatar
Default Re: (letsdrive)
see thats the thing everything is good no leaks no nuthing i just replaced the pcv and cleaned the throttlebody and ran seafoam threw it and its just lacking and like the other guy said if i rev the car up to like 3 grand then its fine and goes good
but if i dont its slugish
Old Oct 27, 2008 | 02:53 PM
ruffrhyder's Avatar
Default Re: (turbozcteg)
Swap your ignition coil, honda coils are notorious for going bad.
Old Oct 27, 2008 | 02:59 PM
felixjr18's Avatar
What all can you clean the throttle body with? I cleaned my old camaro's throttle body with wd40 is that ok to?
Old Oct 27, 2008 | 04:08 PM
trrbl1bmx's Avatar
I would almost bet money on retared igntion timing. First if you don't mind, explain how you are setting your timing, and we might be able to tell you something you are doing wrong.
Old Oct 28, 2008 | 12:00 PM
felixjr18's Avatar
Default Re: (trrbl1bmx)
I haven't messed with my timing or anything and also any info on if its ok to clean the throttle body with wd40?
Old Oct 28, 2008 | 01:25 PM
VegasAD6's Avatar
Default Re: (felixjr18)
i am haveing a similar problem but it is like my car is miss fireing butt only between 2000 and 2500 and i gave it new plugs new wires.
Old Oct 28, 2008 | 04:02 PM
sh4mr0ck's Avatar
Default Re: (VegasAD6)
If you ran Seafoam through your whole fuel system (by putting it in your tank), your filter is most likely clogged...
Try changed your fuel filter, to me, it almost sounds like it's choking itself of fuel...
Old Oct 28, 2008 | 08:46 PM
SOHC_4dr's Avatar
^ good idea. also supercharge it. now you got the low end tq. problem solved
Old Oct 28, 2008 | 09:28 PM
InvaderTrax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trrbl1bmx &raquo;</TD></TR><TR><TD CLASS="quote">I would almost bet money on retared igntion timing. First if you don't mind, explain how you are setting your timing, and we might be able to tell you something you are doing wrong.</TD></TR></TABLE>
Or even cam timing...
Old Oct 28, 2008 | 09:51 PM
ruffrhyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by felixjr18 &raquo;</TD></TR><TR><TD CLASS="quote">What all can you clean the throttle body with? I cleaned my old camaro's throttle body with wd40 is that ok to?</TD></TR></TABLE>
Do not use wd40, use THROTTLE BODY CLEANER, or even Starting Fluid works well.
Old Oct 28, 2008 | 10:04 PM
felixjr18's Avatar
wow its about time someyone answered thanks... throttle body cleaner won't hurt anything correct?
Old Nov 10, 2008 | 07:04 PM
turbozcteg's Avatar
first off my cam timing and everything is dead on
dizzy is advanced a little
after i advanced it it seemed like it went away
changed the coil and still does the same thing
changed plugs and wires and cap and rotor and same thing
and i had a buddy watch the tach and he said it was about 4 when it kicks in
its weird
and i havent checked the iacv yet
but would changing the throttle body give me anything or should i just leave it alone
oj5joker
Jun 26, 2010 12:22 PM
claud122003
Jun 11, 2010 04:28 PM
SexyAzNMami
Mar 17, 2005 12:25 AM
MugenHonda
Jan 11, 2005 05:37 AM
Cottonwoodz
Aug 14, 2002 06:00 AM
