Can't find this fitting anywhere!! 3/8npt to 5/8 barb 90degree!
Old Oct 26, 2008 | 02:09 AM
blinx9900's Avatar
Default Can't find this fitting anywhere!! 3/8npt to 5/8 barb 90degree!
like topic says, i am looking for a 3/8npt to 5/8 barb 90degree fitting, at this point i don't care what its made out of, plastic, brass, SS, aluminum etc... this is for a catchcan setup that uses 3/8npt ports.
i already searched ebay and summit with no luck
Old Oct 26, 2008 | 01:44 PM
NJIN BUILDR's Avatar
Default Re: Can't find this fitting anywhere!! 3/8npt to 5/8 barb 90degree! (blinx9900)
You may end up with a 90* 3/8 npt male / 3/8 npt female, and a 3/8 male npt with a 5/8 barb.I think you will find that a 5/8 barb is going to be a 1/2 npt or larger.
Old Oct 26, 2008 | 02:45 PM
blinx9900's Avatar
Default Re: Can't find this fitting anywhere!! 3/8npt to 5/8 barb 90degree! (NJIN BUILDR)
oh, you mean i might have better luck finding a straight 3/8 npt to 5/8 barb and just using a male/female 90??
Old Oct 26, 2008 | 03:30 PM
Yup.Not the best for flow,but it will work for what your doing.You will probably have to settle for 1/2 " barb.I don't think they make a 5/8 barb to 3/8 pipe.The id of a 3/8 pipe is a lot smaller than a 5/8 barb id.For 5/8 hose you will need to go at least 1/2 npt.
Old Oct 26, 2008 | 05:55 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Yup.Not the best for flow,but it will work for what your doing.You will probably have to settle for 1/2 " barb.I don't think they make a 5/8 barb to 3/8 pipe.The id of a 3/8 pipe is a lot smaller than a 5/8 barb id.For 5/8 hose you will need to go at least 1/2 npt.</TD></TR></TABLE>
i see, your advice has helped me see a lot more options using a 1/2 should not be a problem, i just just forget the whole 5/8 or 1/2 hose thing and get a 3/8npt to -10an adapter and use AN for the rest of my stuff but damn it just gets so expensive!!
Old Oct 26, 2008 | 05:58 PM
If you can live with the the color options than the pushlock stuff works great and is a lot cheaper than AN.
Old Oct 26, 2008 | 09:53 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">If you can live with the the color options than the pushlock stuff works great and is a lot cheaper than AN.</TD></TR></TABLE>
push lock, hmm i saw that but the non swivel is gonna make it hard to install unfortunately, oh wait, i can just install the fitting then push the hose on right?
Old Oct 27, 2008 | 03:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
push lock, hmm i saw that but the non swivel is gonna make it hard to install unfortunately, oh wait, i can just install the fitting then push the hose on right?</TD></TR></TABLE>
Yes.
Old Oct 27, 2008 | 08:17 AM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">like topic says, i am looking for a 3/8npt to 5/8 barb 90degree fitting, at this point i don't care what its made out of, plastic, brass, SS, aluminum etc... this is for a catchcan setup that uses 3/8npt ports.
i already searched ebay and summit with no luck </TD></TR></TABLE>
Here you go...
http://www.mcmaster.com/
Part Number: 53525K22
Old Oct 27, 2008 | 11:42 AM
blinx9900's Avatar
Default Re: Can't find this fitting anywhere!! 3/8npt to 5/8 barb 90degree! (ALLMOTOR18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR18 &raquo;</TD></TR><TR><TD CLASS="quote">
Here you go...
Part Number: 53525K22</TD></TR></TABLE>
i should have known mcmasters would have it lol, thank you so much, i just ordered 2 packs
EdsGTI
Welding / Fabrication
Sep 26, 2008 07:39 PM
Soon_2b_evil
10
Feb 14, 2008 07:13 PM
EJ8 GSR-T
Jul 9, 2006 09:33 PM
Nid Styles
Feb 7, 2004 09:52 AM
