timing belt help
Old Oct 26, 2008 | 01:50 AM
vdawg559's Avatar
Default timing belt help
okay, everytime i would install the belt, it will always b loose. i adjust everything to correct position, but the timing belt is always in wrong.............
i just gave up, an it would like make this weird loud noise
Old Oct 26, 2008 | 05:14 AM
kronikSLOW's Avatar
Default Re: timing belt help (vdawg559)
turn your car off before you blow it up. buy a new tensioner..
Old Oct 26, 2008 | 05:54 AM
bks84's Avatar
Loved
Are you following the correct procedure for putting it on?
Do you have a helms or a service manual available?
I usually start with the cam gears first, then the water pump > tensioner > crank pulley and then adjust the slack with the tensioner. There shouldnt be a lot of slack on the front of the belt, just some slack on the back side though.
Old Oct 26, 2008 | 01:43 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Proper installation procedure is crank pulley > tensioner > water pump > exhaust cam gear > intake cam gear. It is very important to end with the intake cam gear. That way you can stretch the belt tight between the exhaust cam gear and crank sprocket, then let the tensioner loosen when putting it over the intake cam gear. If you put it over the exhaust cam gear last, you will almost always end up with too much slack and your timing will be 1-2 teeth off.
Old Oct 26, 2008 | 03:11 PM
all-mtr-teg's Avatar
do not, I repeat, DO NOT drive the car with a lose timing belt, do not even run the motor. You risk blowing your motor. PM me your phone number, I'm in fresno monday through friday.
Old Oct 27, 2008 | 02:57 AM
vdawg559's Avatar
I SEE. i see. i have mitchell on demand 5 but it doesnt really have pics to show how to install the timing belt correct.....
if i recall. to adjust the crankshaft pully to 0 or what every you called it. there a mark like next to the crankshaft pully ( look something like this --- ) i would line it up where you put the pin for the crankshaft pulley. . is that correct?
Old Oct 27, 2008 | 08:48 AM
letsdrive's Avatar
http://www.team-integra.net/se...=1044
^click that.
Old Oct 27, 2008 | 09:45 AM
AWD Terror's Avatar
Default Re: (vdawg559)
The crank should be set to TDC before you start. Your cam gears should also be aligned.
When I did mine, I bought all new parts. Almost every piece involved was new. Don't want to worry about that **** breaking when you got 300+ WHP
EFjalopy
Jan 8, 2010 02:54 PM
Swansen
15
Apr 1, 2009 02:39 PM
realis9
Aug 26, 2007 12:52 AM
all-mtr-teg
Jan 9, 2007 09:25 PM
EGhatch22
Dec 28, 2004 06:45 AM
