CRX / DelSol wiring loom
Old Oct 25, 2008 | 11:36 PM
fynnbar's Avatar
Default CRX / DelSol wiring loom
Two problems I have with the loom on a 1992 EG2 JDM CRX
1) Secondary oxygen sensor has two wires - one is the braided steel outer, which is obviously an earth, but where does the other (core) wire connect into the loom? I assume it goes to the ECM somehow
2) There is a small sensor / pickup on its own bracket, at the front of the engine bay - two wires - pink from the ECU (shared with the alternator FR terminal), and brown. I need to know where the brown wire connects, and what the sensor is for. Cheers
wickedEFguy
May 20, 2020 03:51 PM
Acc3l3ratoR
May 1, 2019 07:41 PM
orlandoEM2
Mar 23, 2010 07:23 PM
