crx si ebrake cable (for teg rear disc swap)
Old Oct 25, 2008 | 10:48 PM
musasabi's Avatar
Default crx si ebrake cable (for teg rear disc swap)
will these work?
http://www.autopartswarehouse....20CRX
http://www2.partstrain.com/sto...h.y=0
the first raybestos one listed on both of those seems like its the one, but i dont know if thats all i'll need for the swap. also, lower down there are "left rear" and "right rear" ones listed for the dx, hf, and si. whats up with that?
Old Oct 26, 2008 | 06:12 AM
rbwdriven's Avatar
are you trying to put teg trailing arms in a crx.
If that is what your asking then you will need 91 crx si handbrake cables.
if you are trying to do teg trailing arms in a hatch then you will need 92 integra gsr hand brake cables.
Old Oct 26, 2008 | 06:39 AM
musasabi's Avatar
i have a '90 teg gs with everything available for the stealing.
considering that, whats the difference between using the teg trailing arms?
also, would i specifically need the 92 gsr cables, or could i take them off my teg?
Old Oct 26, 2008 | 03:46 PM
rbwdriven's Avatar
if the swap is for a crx the teg cables will too long.
If the swap is for a hatch the teg cables will be fine.
Old Oct 26, 2008 | 04:13 PM
efsublime's Avatar
Default Re: (rbwdriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbwdriven &raquo;</TD></TR><TR><TD CLASS="quote">if the swap is for a crx the teg cables will too long.
If the swap is for a hatch the teg cables will be fine.</TD></TR></TABLE>
x2 on that.
Old Oct 26, 2008 | 06:28 PM
Crx Jimmy's Avatar
Default Re: crx si ebrake cable (musasabi)
Also if you need them just buy them from honda they will fit perfect and you will have the right ones. they can be had for under $50 each from the online discount sellers
Old Oct 26, 2008 | 09:09 PM
musasabi's Avatar
haha, well thanks for the input. i knew the teg cables would be too long for the rex, but none of this has answered my original question. actually, its just inspired two more questions that have gone unanswered. =P
so, one: should i put the teg trailing arms on the crx? what would be the difference between doing it and not? etc
and two: are the parts i linked to in my first post what i need? are they _all_ i need? why are there listings for "rear right" and "rear left" ebrake cables?
right. so more like five questions, but you know what i mean. =P
jaypain
Apr 9, 2009 08:47 PM
sohcvtec91hatch
31
Jan 4, 2007 02:16 PM
HondaHeddie
10
Nov 10, 2006 09:44 AM
bugster
10
Aug 16, 2006 06:19 PM
Pissoff
Jul 20, 2002 04:01 PM
