Need help with a Mugen intake install
Old Oct 25, 2008 | 07:35 PM
soulassassin13's Avatar
Default Need help with a Mugen intake install
I want to install my Mugen intake in my USDM ITR with A/C. I was wondering what is the best method for rerouting the A/C lines, so I can complete the install?
Any insight into to this would be much appreciated.
Old Oct 25, 2008 | 08:10 PM
coolhandluke's Avatar
Default Re: Need help with a Mugen intake install (soulassassin13)
Searching, I found this thread:
https://honda-tech.com/zerothread?id=376228
Old Oct 25, 2008 | 08:25 PM
walker111's Avatar
Default Re: Need help with a Mugen intake install (coolhandluke)
No need to reroute....just bend Do eet gently.
Old Oct 25, 2008 | 08:56 PM
Erik95LS's Avatar
Default Re: Need help with a Mugen intake install (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">No need to reroute....just bend Do eet gently. </TD></TR></TABLE>
yep, very simple.
Old Oct 25, 2008 | 09:10 PM
I will have to try and split the A/C lines.... Thanks for the info. I wish the links weren't broken for the photos.
Old Oct 26, 2008 | 12:05 AM
YellowKahuna's Avatar
Default Re: (soulassassin13)
I put in my intake not to long ago. It was a pain in the ***.
I had to move the radiator out of the way for a moment to get that sucker in.
Its a tight fit and frustrating cause it uses up all the space. I was impressed how exact it fit in that area .
Old Oct 26, 2008 | 05:37 AM
walker111's Avatar
Default Re: (YellowKahuna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowKahuna &raquo;</TD></TR><TR><TD CLASS="quote">I put in my intake not to long ago. It was a pain in the ***.
Its a tight fit and frustrating cause it uses up all the space. I was impressed how exact it fit in that area .</TD></TR></TABLE>
It gets easier after the first time.
Old Oct 26, 2008 | 06:28 AM
94VTEC2TONE's Avatar
did you notice a good gain after puttin in the mugen. i was thinkin bout running it in my all motor setup
Old Oct 26, 2008 | 06:48 AM
get RIGHT's Avatar
Default Re: (walker111)
It gets easier after the first time. </TD></TR></TABLE>
Indeed. I find its easier to build it from the bottom, up.
Old Oct 26, 2008 | 08:05 AM
Comp97GSR's Avatar
Default Re: (get RIGHT)
After the first time, as Walker said, it is sooooo easy. I have pics of how I routed the a/c lines I can send you through PM's if you'd like.. Like KKim's thread, my threads pics are no longer working.
Removing the A/C condenser fan and moving the radiator over to the drivers side is the easiest way to install. I have also found that under the car, near the middle of the radiator there is a bracket the holds the a/c lines. When that is removed it makes it much simpler to move the radiator and to spread the a/c lines.
Old Oct 26, 2008 | 08:14 AM
BMaDOHC's Avatar
Default Re: (Comp97GSR)
mine went right in. move a couple lines and brackets and presto! no need to take radiator out, thats just making more work for yourself. its a tight fit but isnt that bad with a little bit of patience
Old Oct 26, 2008 | 08:21 AM
Comp97GSR's Avatar
Default Re: (BMaDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMaDOHC &raquo;</TD></TR><TR><TD CLASS="quote">mine went right in. move a couple lines and brackets and presto! no need to take radiator out, thats just making more work for yourself. its a tight fit but isnt that bad with a little bit of patience</TD></TR></TABLE>
Nobody said to remove the radiator. I am curious, did you remove the lower trannie mount to do this without moving the radiator over?
Old Oct 26, 2008 | 08:23 AM
I didn't take the radiator out, just moved it over towards the left front.
Taking out the whole radiator
I left the tranny mount in. At the time I didn't have the tools to take that big bolt out.
Old Oct 26, 2008 | 08:25 AM
tartje's Avatar
I didn't need to move or remove anything except the standard airbox, the wheel and the ****-guard.
Old Oct 26, 2008 | 08:36 AM
Erik95LS's Avatar
Default Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">I didn't need to move or remove anything except the standard airbox, the wheel and the ****-guard.</TD></TR></TABLE>
But your car is backwards
Old Oct 26, 2008 | 08:40 AM
tartje's Avatar
Default Re: (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">
But your car is backwards </TD></TR></TABLE>
bleh
the A/C lines run on the opposite side of the car, but everything else is in the same place I thought?. It literally took about 10seconds of jiggling and it slotted right in. The longest part was working out how to install the little shield that prevents water getting into the intake duct.
Oh, and there was a small bracket that helps to hold the stock airbox, that came out also.
Old Oct 26, 2008 | 08:43 AM
Comp97GSR's Avatar
LOL, you spent the most
time on the easiest thing to install??? Besides, who really needs the shield?
Old Oct 26, 2008 | 08:46 AM
tartje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">LOL, you spent the most
time on the easiest thing to install??? </TD></TR></TABLE>
exactly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Besides, who really needs the shield?</TD></TR></TABLE>
the last thing I wanted was to hydrolock my motor because of 5minutes of laziness. shrug.
Old Oct 26, 2008 | 08:49 AM
Comp97GSR's Avatar
Mang, You'd have to submerge the entire snorkle in a puddle to accomplish that..... and a shield won't help ya there. Should help keep debris from getting sucked up to the filter in theory but I haven't noticed a difference with or without the shield.
Old Oct 26, 2008 | 08:52 AM
tartje's Avatar
I know what you're saying, but I just figured that if I've got the shield, may aswell stick the fugger on there
Old Oct 26, 2008 | 01:32 PM
get RIGHT's Avatar
I thought that shield was pretty confusing too.
Old Oct 27, 2008 | 04:28 AM
BMaDOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by get RIGHT &raquo;</TD></TR><TR><TD CLASS="quote">I thought that shield was pretty confusing too. </TD></TR></TABLE>
haha, that was my most difficult part too. trying to use the pics in the directions to see which way the shield goes.
Old Oct 27, 2008 | 04:36 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">Removing the A/C condenser fan and moving the radiator over to the drivers side is the easiest way to install. I have also found that under the car, near the middle of the radiator there is a bracket the holds the a/c lines. When that is removed it makes it much simpler to move the radiator and to spread the a/c lines. </TD></TR></TABLE>
BINGO!!!
Having just "removed" mine, it's all getting used to how it goes in there. Twist it this way, shove it that. But it works, and with AC.
Old Oct 27, 2008 | 04:51 AM
Bradstard's Avatar
Default Re: (Dave_B)
I had the motor out of the car with made it pretty easy to install.
Old Oct 27, 2008 | 06:15 AM
Type-R Yo!'s Avatar
New User
Default Re: (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">I had the motor out of the car with made it pretty easy to install.</TD></TR></TABLE>
Thats cheating
And I install it for you after I went through all that AC crap with mine.
