Did the 1991 CRX dx come with sunroof stock?
Bought a 1991 crx dx and it has a moon roof. did this model come with a moon roof or is it aftermarket? pics would be helpful. thanks
Modified by little2fast4u at 8:03 PM 10/25/2008
From what I understand, only the Si has the stock moonroof. I have yet to see a dx or ef with the same sliding roof as the Si.
Is it an electric sliding moonroof with a switch on the dash? If so, no, that was an Si only feature. I've seen EFs with roof swaps, but it is pretty unusual. If it is a pop-up piece of glass then that was aftermarket, I believe.
it is a glass pop up piece. the reason im asking is cuz my seal is worn and the plastic mounting pieces are begining to crack. should i just fix it, replace it, seal it back to stock or put a kevlar plug in place of it?
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">FYI the was no CRX DX, there was only a CRX Hf, CRX, CRX Si</TD></TR></TABLE>
The standard or base model CRX was refered
to as a "DX" in the factory service manual:
Please note line 5 under vehicle grade..
The local Honda dealer also stated that by the VIN number that my car was a DX.
If you go to Majestic Honda http://www.hondaautomotivepart...h.jsp
and run a parts search on 88-91 models,DX is also listed of the three trim levels..
PS> There was a dealer installed option for the pop-up sunroof..
What does you vin on the fire wall say? ED8 or ED9? It's more likely the previous owner swapped in a D15 and said it was a DX then do a roof swap. Check the vin, ED8 = DX (not sure about HF's) ED9 = SI.
And yes it was a option.
Tyson
13
Oct 28, 2004 03:04 PM
madhatter07
Mar 1, 2004 09:40 AM
