Check engine light code 6, ect good, getting 5 volt signal, need ecu????
Old Oct 25, 2008 | 04:50 PM
snakey5138999's Avatar
Default Check engine light code 6, ect good, getting 5 volt signal, need ecu????
Hey guys im looking to buy a 1989 honda accord lxi FI from my friends dad for about $150 with 110k on it. The only thing wierd about the car
is it cranks and cranks but does not start. He has to put his foot to the floor to clear flood mode and then it starts. He thinks its because of the check engine
light. He has a check engine light for a code 6(ect sensor open or short).
Do you guys think this would make sense??? the ecu isnt able to read the ect so it thinks its cold, causing the car to flood and create a bad mixture and not be able to start. What do you guys think??
We checked the ect sensor resistance and it was good. Next test was to check if the sensor was getting a 5 volt reference, and it was so thats good.
Then it lead me to replacing the ecu since the other 2 test passed, according to Mitchell on demand. Maybe a circuit blew, not letting the ecu to receive a signal back from the sensor. Im wondering if replacing the ecu is common in these older cars? Where would i be able to buy one? does anyone on here have one if i need it?? Need some diag help.....anyone experience this or can back me up on some info???
Darth CRX
Apr 29, 2014 07:33 AM
snakey5138999
Oct 28, 2008 02:13 PM
bstaralways
Sep 4, 2007 02:51 PM
stockintegra
Mar 27, 2004 02:13 PM
CivicHB91
Jan 22, 2003 03:31 PM
