Potential vacuum leak on a B-series swap
ok everyon let me first say that i have searched all day and have not found anything and i need your help. here is the issue, i just recently put a b16a(obd10 into my 00 civic ex 5spd, i did all the necassary wiring and am using an obd1 p30 ecu, the car starts and idles like crap, i have tried adjusting the timing and nothing, also same with the tps i move it and it get worse so i put it in its original position, whenever i hit the gas it just bogs down untill i let off then it idles, but if i keep on it will die. also i checked the timing belt and everything lines up. i am running a b18c1 head w/ skiunk2 intake mani w/ edelbrock tb, it seems like there is a vacume leak but iv checked and checked and cant find anything, thanks for your help.
Modified by stock ek at 5:54 PM 10/25/2008
Nicaraguense13
May 20, 2006 09:01 AM
Stoich
28
Jul 5, 2005 09:29 PM
JSPECHB
Mar 27, 2004 07:17 PM
