Which master cylinder upgrade should I do?
Old Oct 25, 2008 | 02:11 PM
ludesrv's Avatar
Default Which master cylinder upgrade should I do?
I have the EX civic front brake upgrade on the wagon and the MC is leaking into the brake booster, so both should be changed. I was reading into the 90 Teg non ABS MC/BB upgrade or the EX civic MC with stock brake booster. Price set aside, what are your opinions on which upgrade to go to? Should I change the prop valve also? I have the stock wagon one with stock rear drums.
Old Oct 25, 2008 | 02:37 PM
sgallagher's Avatar
Default Re: Which master cylinder upgrade should I do? (ludesrv)
If you have the front brakes from an EX and the stock rear drums you might as well upgrade your wagons system to mirror the EX. Use the EX m/c and booster and the EX prop valve(if its diff.)
ej14life
Nov 26, 2009 04:33 PM
SmellsLikeMustand
Jul 10, 2009 05:16 PM
92Lshatchback
Feb 12, 2007 07:27 PM
Cory man
10
Feb 1, 2005 08:44 AM
