painting car interior... need help!
Old Oct 25, 2008 | 01:51 PM
bigsnorlax's Avatar
Default painting car interior... need help!
this is going to sound dumb. But can i rly just paint my front console? i dont like the ugly grey color and was wondering if u think i could just paint the cup holder, center console, etc. And if so do u think it would look really bad? im worried itll show all these brush strokes. or i could spray paint.... but then id have to remove everything haha
Old Oct 25, 2008 | 02:32 PM
gianinline's Avatar
If you use a brush, it will leave some lines from brushing the paint on it.
If you spray paint it, and do it right, it will hold it strong, last and you will be happy with the result.
It's not impossible to remove the stuff, you can have everything done in one day (including removal, prep and paint) and re install everything back on the next day.
Old Oct 25, 2008 | 03:17 PM
bigsnorlax's Avatar
Default Re: (gianinline)
oh wow, i just had though console removal would be a huge pain liek all the wires n stuff. U have any recomendations for spray paint? i meant i dnt really need any special kind would i? What im afraid of is that if i paint those rubbery parts ( u can kinda push them with ur finger and they go down a lil bit) that the dry paint would crack or something
Old Oct 25, 2008 | 03:32 PM
bseriescrxsi's Avatar
Default Re: (bigsnorlax)
make sure you use car interior paint and make sure you clearcoat it so itll last and you should be fine
Old Oct 28, 2008 | 06:54 PM
tpot90's Avatar
Default Re: (bseriescrxsi)
The center console, shift **** frame, and cup holders are usually really easy to remove. Just a little patience and strength will pull the tabs out of their place, and itll come right up.
Use KRYLON Plastic paint.
Post pictures when youre done with the project..you might inspire somebody.
Old Oct 28, 2008 | 07:08 PM
collins97's Avatar
Default Re: (tpot90)
if your talking about the part with the radio it isnt hard to take out at all and its easy to spray just make sure u sand it first and use surface cleaner ( wax and grease remover) prime it ( wax and grease remover again) then paint 3 min flash times between coats and about 3 coats dont rush it bc paint takes alot of time and patients so if u rush it its going to [freak] up and look like ****
i did everything in my show car did it right tho and fiberglassed it and painted it with nason full base base coat, clear coat but you could go to a paint shop and get your paint code matched up in a spray can its a single stage enamel so you wont have to spray a clear coat and it will stand up if you dont rush it and do it right
Old Oct 28, 2008 | 07:24 PM
slomofo's Avatar
GDD Member
I painted my entire dashboard black (from Tan) back when I was a ricer. I took it out, ran down to an autobody supply store to pick up a quart of DuPont black paint ($30), then ran it down to a bodyshop that charged me $80 to prep/paint it. It came out looking like a factory black dashboard.
If you can't paint it right on your own, you could always run it down to a bodyshop like I did and pay them a few bucks to do it.
Old Oct 29, 2008 | 10:27 AM
professorman's Avatar
Default Re: (slomofo)
Humm, I havent seen many painted interiors, but the ones that I have seen all look crappy. Post up some pictures and let me see.
Civic98KH
Mar 21, 2007 03:26 AM
spongerx
Dec 29, 2006 01:48 PM
CivicNA
Jul 5, 2003 08:17 PM
GrnCivic97
Aug 21, 2002 11:21 AM
BigZ88
Jun 18, 2002 08:44 AM
