hard grind when going into 5th..
Old Oct 25, 2008 | 01:33 PM
buffdaddy357's Avatar
Default hard grind when going into 5th..
I have a hard grinding sound only when I go into 5th gear. Can anyone help?
Old Oct 25, 2008 | 02:34 PM
gianinline's Avatar
Are you driving a 94-95 accord?
Old Oct 25, 2008 | 06:39 PM
Default Re: (gianinline)
94 accord
Old Oct 26, 2008 | 04:05 AM
P_Adams's Avatar
Default Re: hard grind when going into 5th.. (buffdaddy357)
If it's 5th gear (and 5th gear ONLY)
Honda had a TSB on this condition. Related to the trans being (or had been ) refilled with the incorrect trans fluid. This effectively starved lubrication in portions of the tranny case; effectively trashing 5th (and sometimes 4th as well)
Try a Drain/Refill using the correct Honda lube and see what happens.
If it does not help, you're most likely looking at a teardown involving Syncro's and Shift Forks.
P
Old Oct 26, 2008 | 07:56 AM
gianinline's Avatar
I friend of mine had his 5th gear grinding on his 94 accord, he drained the tranny fluid, and refilled with synthetic oil, and amazingly, it had "solved" the grinding. Now that's just one opinion before you go ahead and take your tranny out and put another one in.
Old Oct 30, 2008 | 10:10 AM
Thanx, I will give it a try.
Old Oct 31, 2008 | 05:45 AM
jweller's Avatar
Default Re: (buffdaddy357)
You could also give syncromesh trans fluid a try. A lot of guys swear by it. It's a GM product, so you can get it at any parts counter, but it's also available at some auto parts stores
Old Oct 31, 2008 | 05:47 AM
Ross 2.0's Avatar
In a Junkyard near you.
Honda has a new and improved MTF that beats synchromesh IMO. It solved the grind my 89 LX-i had.
Rkolczak
Transmission & Drivetrain
Oct 4, 2010 09:26 AM
legomytego
Mar 28, 2009 01:29 PM
corymedlin
Dec 22, 2003 09:10 PM
chuteBOXE
Apr 13, 2003 02:34 PM
John
Feb 12, 2002 12:16 PM
