civic doors
ok my civic's doors are wierd when you open then they feel like they are resting on the door jam area it like someone rested on the door and bent it down some how can i fix this???
On the two hinges holding the doors on, loosen the bolts up on the bottom hinge. Then you or have someone else lift up on the door a little while you tighten them back up. Then test the door by shutting it to see if it still rubs. Might have to do it a couple times till you get it perfect. Then after wards you might have to raise the latch on the door jam depending if that was low as well so it shuts right. That's just as easy as loosening up the two bolts holding it and sliding it up ever so slightly.
jedubz
Feb 29, 2004 02:17 AM
tha Big EZ
Dec 4, 2003 10:47 AM
