Can't Change Spark Plugs Even With a 3" Extension
Okay, looks like I need to run to Sears I guess. I can't change the spark plugs even with the 3" extension... they are just too far down there. What do you guys use to change the plugs?
i use the 6" extension with spark plug socket with the rubber boot inside it to hold the sparkplug
on me.Thanks
Craftsman sells a very nice 3-piece extension set for $19.99, and they have the anti-release-locks on the ends, which is a nice feature.
i wasn't being sarcastic was I? Sorry If I was. I just use the 6 inch extension
Flux - who is on his way to Sears
Or you can put all your extensions together to make a super duper long extension. I remember once Jedi Master put 3 extensions together but in the end, he used his force to get off that bolt!
longer extension of course.. however I never can find the spark plug socket so I don't even bother with it anymore. Normal socket + a spark plug wire + longer extension = no spark plug in h0l3
Just wanted to post up something I run into occassionally, but when you are putting new plugs in, after you tighten them, sometimes the spark plug socket will come off the extension and stay down there! I've had this happen even with a Snap On extension that has the anti-release. Simple fix? I just got some duct tape and taped the damn spark plug socket onto the extension. Problem solved. Just wanted to mention because it took me a little to figure a good easy way to solve this problem. Yeah, I know
while you're out, get some anti-seize for the plug threads
W95civicEXcoupe
11
Oct 27, 2014 10:01 AM
SpeedMonkeyRacing
Apr 24, 2003 08:55 PM
